CX to EX/Si cluster???
Will installing the EX/Si (tachometer) gauge cluster be a plug-and-play swap on a 92 CX (no tachometer)?
The speedo on my car is dead (I used the Helm's debug tree in the FSM, it is not the VSS).
I figure getting a used cluster of Eby is probably much less expensive than buyng a new speedo from the dealer. And, if it's plug-and-play, I get a tach as well.
and if u want to keep the same mileage all you have to do is swap the center speedo with your current cx one into the ex one and ur set to go.
putting an ex cluster in a cx is plug and play and prewired!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC dude »</TD></TR><TR><TD CLASS="quote">and if u want to keep the same mileage all you have to do is swap the center speedo with your current cx one into the ex one and ur set to go.</TD></TR></TABLE>
Can't - the reason I'm doing the swap is the speedo is not working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">putting an ex cluster in a cx is plug and play and prewired!</TD></TR></TABLE>
Sweet. Thanks.
Sweet. Thanks.
MotoCARR
Nov 24, 2014 10:33 AM
Pat_S
Jan 14, 2010 04:00 PM
dpine
Apr 6, 2007 01:52 PM
tuanizdashtz
10
Jul 28, 2005 11:21 AM
CIVIC dude
24
May 12, 2005 02:09 PM
