195 vs. 205 on 15 in. rims...
Old Mar 21, 2004 | 09:43 PM
wizzards581's Avatar
Default 195 vs. 205 on 15 in. rims...
whats the advantage and disadvantages of using 195 or 205 on 15' rims?
example.
-195/50/r15
-205/50/r15
dohcMONSTER's Avatar
Default Re: 195 vs. 205 on 15 in. rims... (wizzards581)
rubbing
Old Mar 21, 2004 | 09:51 PM
Touch's Avatar
Default Re: 195 vs. 205 on 15 in. rims... (sohcMONSTER)
off topic, but that isht if hilarios
Spooled1.6L: "I always wanted to get like 100 cars with mad crazy vtec to go drive through a tunnel all at the same time and all hit 9k at the same time, and see if we could suck all the oxygen out of the tunnel and kill ourselves"
Old Mar 21, 2004 | 09:55 PM
mr poo's Avatar
gearing is a big consideration/ deciding point
i went with 195-55-15 cuz i live 300 miles from school and visit home often. i prefer the taller gearing compared to the other possible 15inch tire choices
Old Mar 21, 2004 | 09:58 PM
Default Re: 195 vs. 205 on 15 in. rims... (Touch)
Old Mar 21, 2004 | 10:11 PM
biassj's Avatar
Width/Aspect Ratio/Wheel Diameter
Tire Diameter:
205/50/15 = 23.1
195/55/15 = 23.4
195/50/15 = 22.7
**195/50/15**
Advantage:
Smaller tires will result in higher final drive(number wise). For example, 4.40 into 4.60. The higher the number, the closer the gear is.
Disadvatge: Your speed gauge will be off, increase in final drive equals less gas mileage, traction is better with wider tires.
**205/50/15**
Pretty much opposite. Wider tire, more traction. Wider gear ratio, or stock like.
Modified by biassj at 1:21 AM 3/22/2004
Old Mar 21, 2004 | 10:16 PM
JforJonathan's Avatar
Default Re: 195 vs. 205 on 15 in. rims... (biassj)
good info there
biassj's Avatar
Default Re: 195 vs. 205 on 15 in. rims... (Dj Villain)
Kind of edited it, heheh.
Old Mar 22, 2004 | 12:08 AM
95eg6's Avatar
i like 195's because I usually keep my car at a 4" drop
Old Mar 22, 2004 | 12:12 AM
b16aEGcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biassj &raquo;</TD></TR><TR><TD CLASS="quote">Width/Aspect Ratio/Wheel Diameter
Tire Diameter:
205/50/15 = 23.1
195/55/15 = 23.4
195/50/15 = 22.7
**195/50/15**
Advantage:
**205/50/15**
Modified by biassj at 1:21 AM 3/22/2004</TD></TR></TABLE>
umm the only differene between the two sizes is the width of the tires which has absolutely nothing to do with a greater diameter or gearing. basically you would want a wider tire for things like auto-x and better traction, where as the 195 would be prefered on a car that is dropped alot because of potential rubbing issues.
Old Mar 22, 2004 | 12:22 AM
hooter's Avatar
Default Re: 195 vs. 205 on 15 in. rims... (b16aEGcivic)
Actually, since the aspect ratio is a percentage of tire width, sidewall height *is* affected by the tire width. A 225/50 is going to have a much taller sidewall than a 195/50 and will contribute to a tire with a larger diameter, which will ultimately affect gearing.
A 225/50-15 for example will give you a 23.86" ovrall diameter, numerically decreasing gearing (making it longer).
Check out this link for more info on how to read tire markings.
-Charlie
Old Mar 22, 2004 | 12:38 AM
Default Re: 195 vs. 205 on 15 in. rims... (hooter)
between a 195 and 205 you will not find enough of a difference at least through my experience for it to really matter nor take into acount the 1mm difference in sidewall height is what I was gettin at
big.turbo.daddy
May 1, 2015 09:56 PM
phenoyz
Apr 13, 2012 11:12 PM
wolf95
Mar 15, 2009 06:50 PM
speedehatch
Apr 1, 2004 05:17 PM
snowman
Jan 26, 2002 11:59 AM
