92 civic swap to A6
im building a d16a6 to put in a 92 civic 4 door.
using original z6 v-tec head for the swap.
srp pistons: the bore is 2.953 and stroke 3.543 (im almost sure this is the standard bore and stroke)
connecting rod bearing set and engine main bearing set for A6... (they fit eagle rods?? not quite sure)
eagle rods for A6..
using all other components from Z6..
will everything match up?? is there some things the z6 has that the A6 doesnt??
also, this is for a turbo set up.
anything worth my knowledge will help me in any way possible. thanks.
email boostedvtec92@yahoo.com if you have some really good facts.
eagle rods for A6..
Txdragon
Engine Machining & Assembly
14
Feb 10, 2018 04:53 AM
