car wont start
Old Mar 21, 2004 | 02:14 PM
EK9Blitz's Avatar
Default car wont start
i have a 96 civic hb with a type r engine inside. it was running fine when we put the engine in but it overheated a little and had a minor oil leak. I fixed both of the problems and when I tried to start it again it would not start. It would crank but not start.... Now i dont know what is wrong. Any opinions would help... thx
Old Mar 21, 2004 | 03:39 PM
Noe Kozz's Avatar
Default Re: car wont start (EK9Blitz)
Need more info, does the car turn over? If the car turns over, are you getting spark? Again, need more info.
Old Mar 21, 2004 | 04:58 PM
Clutchmasta55
Guest
Posts: n/a
Your engine may be flooded assuming you've tried everything else. Pull a spark-plug out if tip is wet and smells like gas remove all plugs and allow them to dry. After the plugs have dried re-install plugs and try to start her again.
Good luck
Old Mar 22, 2004 | 02:08 PM
EK9Blitz's Avatar
Default Re: car wont start (Noe Kozz)
the car doesn't turn over and it doesn't sound like it has spark.
i'm pretty sure it has enough gas getting to it
Old Mar 22, 2004 | 05:32 PM
LSVTEC 91 Civic's Avatar
Banned
Heres how to check for spark...
Pull the plug out, stick a screwdriver in the plug, lay the screwdriver handle on something, make sure the metal part of the screwdriver makes contact with plug, make sure metal part of screwdriver is close do something that is metal under the hood. Then, crank the engine and look for spark.
If you're getting spark, check to see if you're getting fuel. Pull fuel line off, is the line pressurized?
xXViperXx
13
Jan 14, 2015 09:31 PM
FunStuff
Aug 1, 2007 03:15 AM
bmxbikes
22
Jul 4, 2007 07:23 PM
ICeDoUt
Aug 18, 2005 01:38 PM
Peligro
Jun 21, 2003 06:43 PM
