b16 turbo not starting...need help pleeees
Old Mar 21, 2004 | 11:57 AM
mitsuman's Avatar
Default b16 turbo not starting...need help pleeees
well i raced this guy last night, i beat him but then when i let off the gas the car just turned off. i pull over thinkin i blew her. no oil anywhere. so im like ok. i try to start and it wont start. doesnt sound like its compressing. well today i tow it to my buddies house and we check compressioin, spark, fuel, timing belt. all seems to be good. its a b16a 1st gen stock block, custom kit, boostin 7 psi. was tuned at 6 psi made 230 153trq. i took the plugs out and there was fuel all over them. seems like my timing is probably off. how can i check the dizzy? any body got any suggestions? if anyone can come down and take a look at it id appreaciate it ($$)
im in fountain valley if you can come gimme a call at 714-679-9602 thanks
Old Mar 21, 2004 | 01:03 PM
mitsuman's Avatar
Default Re: b16 turbo not starting...need help pleeees (mitsuman)
up
Old Mar 21, 2004 | 01:23 PM
b16ahybrid's Avatar
Do you have spark? It sounds like your not getting any spark, and thats why your plugs are covered in fuel. Pull your plug wire out a bit when cranking to see if it arcs, if not thats your problem
Old Mar 21, 2004 | 02:46 PM
mitsuman's Avatar
Default Re: b16 turbo not starting...need help pleeees (b16ahybrid)
i havent checked the spark at the plug but i checked it coming out of the dizzy. and i am getting spark. maybe the prob is in the wires? but i highly doubt that all the wires went bad at the same time. i will check it out though. any way to check if my dizzy is off? thanks for the help
Old Mar 21, 2004 | 02:50 PM
Mad Cow's Avatar
Timing belt slipped, probably. Take off your valve cover and see if your cam gears are where they should be, and check that the belt is at the proper tension.
Old Mar 21, 2004 | 02:53 PM
mitsuman's Avatar
Default Re: b16 turbo not starting...need help pleeees (MadCow)
the belt is a tiny bit loose but the aem cam gears are right on.
Old Mar 21, 2004 | 08:05 PM
mitsuman's Avatar
well i swapped out the dizzy with one i knew worked and nada, i am getting spark at the plug. could it be some sensor? i will pay somebody to come fix it. i need this car running asap. thanks
Old Mar 21, 2004 | 08:24 PM
1.8turbolsvtec's Avatar
what was the numbers of the comp test
Old Mar 21, 2004 | 10:31 PM
iaintnogangster's Avatar
Default Re: b16 turbo not starting...need help pleeees (1.8turbolsvtec)
Is this the civic that you just bought?
Old Mar 21, 2004 | 10:35 PM
mitsuman's Avatar
Default Re: b16 turbo not starting...need help pleeees (straitryder)
yep just bought her. dont have compession numbers yet.
Old Mar 21, 2004 | 11:19 PM
nigel's Avatar
did you see smoke in the rearview? also you need to get that thing comression tested. if you have fuel and spark ,and your timing is ok it may be blown. also you should check your oil to see if you have any water in it.
Old Mar 22, 2004 | 09:52 AM
mitsuman's Avatar
Default Re: (nigel)
i did see smoke in the rear view but im almost positive that it was from peeling out through 2nd gear. cuz i shut it down soon after i shifted into 3rd. and i usually see a good amount of smoke from not getting any damm traction. no bubbles in my radiator so im sure i didnt blow my HG. i do have spark but timing may be off. could it be some sensor? ima take it to a shop today see if they can fix the problem. but if anybody else has any ideas please let me know.
Brandeno
May 31, 2015 08:55 AM
scotty.b16a1
Dec 31, 2012 01:54 PM
SimplyTron
Feb 19, 2007 12:08 PM
crx90rcr
Nov 1, 2006 08:48 AM
QTKEG6
Jun 23, 2002 10:14 PM
