B16 EG cluster.
Old Mar 21, 2004 | 10:02 AM
justBLZE's Avatar
Chopper 2 Hopper
Default B16 EG cluster.
My friend just bought a 92 Civic Si with B16 engine and the stock cluster is off on the RPMs.
Which cluster should we buy to get accurate readings?
Old Mar 21, 2004 | 10:04 AM
compwc18's Avatar
Default Re: B16 EG cluster. (tommy69)
you should get a AutoMeter 5" Sport-Comp Tach... thats what I use, since I dont even have a tach on my cluster...
Old Mar 21, 2004 | 10:05 AM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: B16 EG cluster. (compwc18)
He actually has one of those tach's from the previous Civic he owned.
I was thinking that there might be a cluster that will work fine with the swapped engine.
Old Mar 21, 2004 | 10:12 AM
compwc18's Avatar
well then why doesnt he do that... there was a guy here on HT that installed a GSR cluster into a EG awhile back... lookedgood but it takes way too much time...
Old Mar 21, 2004 | 10:13 AM
justBLZE's Avatar
Chopper 2 Hopper
I guess he wanted to keep the clean look, without the monster tack in the middle
Wouldn't a JDM SIR cluster work?
Old Mar 21, 2004 | 10:18 AM
92b16vx's Avatar
And how exactly do you know his cluster is off? Are you measuring it against a digital tach, or another caliberated tach?
Old Mar 21, 2004 | 10:20 AM
compwc18's Avatar
Default Re: (92b16vx)
well mt tach isnt in the middle, i have it in the corner next to the door, it looks really good there :-D
Old Mar 21, 2004 | 10:21 AM
justBLZE's Avatar
Chopper 2 Hopper
Idles at 1500 RPM and goes all the way to 9RPM when shifting with a stock B16A.
Then again while crusing 80 his tach is at 4000 RPM when I think it should be at 4400 unless he has different gear ratios.
Still gotta figure that out.
Old Mar 21, 2004 | 10:23 AM
compwc18's Avatar
Default Re: (tommy69)
maybe hes revving the motor too high... b16's, you should shift around 8,000 thats where i shift... my revlimiter is at 8200 but im also running the obd1 p72 chipped ecu
Old Mar 21, 2004 | 10:29 AM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (compwc18)
It's a B16A with LSD tranny (S4C on the cast) and the JDM P30 ECU.
Old Mar 21, 2004 | 10:30 AM
92RED Hatch's Avatar
yeah dude...9 grand is way too high with a B16 with stock valvetrain. Plus there isn't any power up that high as well
Old Mar 21, 2004 | 10:31 AM
compwc18's Avatar
Default Re: (92RED Hatch)
that is true.... id say use the auto meter tach, they are also pretty accurate :-D
Old Mar 21, 2004 | 10:32 AM
compwc18's Avatar
also, if u just use the auto meter tach that he had before, then he could save that extra money for a sluter and get something for the motor
justBLZE's Avatar
Chopper 2 Hopper
I think the rev limiter is still at 8200 but since the tach is 500RPM too high it looks like we shift at 9K that's the whole point of that post.
Old Mar 21, 2004 | 10:59 AM
Kevedge's Avatar
just go buy the sir cluster, passwordjdm has them for 170. its a nice cluster because the tach is for the motor, so the redline and everything is for the B16. plus it lights up amber
Old Mar 21, 2004 | 11:05 AM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (Kevedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevedge &raquo;</TD></TR><TR><TD CLASS="quote">just go buy the sir cluster, passwordjdm has them for 170. its a nice cluster because the tach is for the motor, so the redline and everything is for the B16. plus it lights up amber </TD></TR></TABLE>
That's exectly what I told him to do, just wanted to make sure it will work fine with the B16 motor, thanks for your help.
Old Mar 21, 2004 | 11:16 AM
Kevedge's Avatar
Yepp, it will work fine. Thats what me and a friend are running. Both have b16's. Plus the cluster plugs right in, no extra wiring needed. I think the only things that dont work is the srs light doesnt come on, but there are right ups on making it so you can have it turn on.
Old Mar 21, 2004 | 12:18 PM
92b16vx's Avatar
My VX cluster worked perfectly with my B16A.
Supa Troopa
62
Jul 19, 2023 10:07 AM
V.MoMO
Sep 12, 2010 08:44 AM
89DXDann
Jun 4, 2004 11:38 PM
GDM Z28
Feb 1, 2004 01:10 PM
