brake light problem
i got a 00 civic si and my dash brake light stays on. It gets brighter when i pull up on the e-brake. I checked the fluid, and it was maybe a little low, so I filled it up. The light is still on though. what can my problem be? do i need to reset the ecu?
the ebrake light? if that is what you are talking about, follow the ebrake wire through the back of the car, and see if it may be engaged anywhere. also find out where the switch to turn on the light is, and check that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie »</TD></TR><TR><TD CLASS="quote">mine did that and all it was a blown bulb
all my bulbs are working. dash light still on
swap the cap with another one the floats DO fail..... it has nothing to do with the parking brake because the light gets brighter when u pull the lever up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic »</TD></TR><TR><TD CLASS="quote">swap the cap with another one the floats DO fail..... it has nothing to do with the parking brake because the light gets brighter when u pull the lever up</TD></TR></TABLE>
i will try swapping caps.
how can i check my e-brake cable?
I took my cap off and messed with the floater a lil bit. I guess it was the float. Light went off when i put it back on. Thanks. Problem solved
HA0LEFIED
Nov 28, 2008 12:55 PM
