5th Gen Door Panel
WHo can give me some good instructions on getting the door panel off.
I want to fix my door lock actuator (regulator) and upgrade my speakers.
Thanks for the help
JEFF
Thanks for the help
JEFF
Remove the screw that secures the door handle..
Remove the Door Handle by pushing it foward, then remove the linkage from the handle..
Remove the screw in the door grab handle/pocket, and remove the handle/power window switch assembly by moving it foward while lifting it up..
Pry up the bottom of the speaker grille to remove it, remove the 3 screws embedded in the door panel, remove the 3 speakers screws that hold the speaker in place and unplug the speaker connector...
Roll the window down, pull out on the door panel just underneath the speaker location and free the door panel..
Thanks
The speaker grills do not have screws ???
I attempted to pry it off the other day but it would not pop off. I didnt want to snap anything so I gave up.
Also
Is the window being rolled down necessary to get the door panel off ?
JEFF
Also
JEFF
1997exciv12w3
Sep 3, 2002 05:12 PM
