Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what do I need to pass tech inspection?
Old Oct 21, 2001 | 04:08 PM
DSGB.'s Avatar
Dirty Bird
Default what do I need to pass tech inspection?
------^ Title
Old Oct 21, 2001 | 04:30 PM
Crack Monkey's Avatar
Default Re: what do I need to pass tech inspection? (Blurple92si)
For autocross?
Good tires (no cords)
Wheel bearings, no play
Lug nuts, all present
Throttle return working
Battery tied down
Trunk, passenger area empty
M90 or SA90 helmet (loaners usually available)
Old Oct 21, 2001 | 04:53 PM
DSGB.'s Avatar
Dirty Bird
Default Re: what do I need to pass tech inspection? (Crack Monkey)
I guess, Solo II
Old Oct 21, 2001 | 06:52 PM
WRXRacer111's Avatar
You'll want to have your lugs nice and tight too, ~80lbs-ft. I believe there is a minimum tire pressure requirement of something like 30psi, but you'll want to be well above that anyways for optimal tire performance and life.
Old Oct 22, 2001 | 06:41 AM
00R101's Avatar
Default Re: what do I need to pass tech inspection? (WRXRacer111)
There is no minimum tire pressure but common sense says that on street tires you probably want 40+
DO NOT OVERTORQUE YOUR LUGS - Use the factory recommended setting (often 80ft-lbs) The odds are good if you are not changing tires you don't need to worry about this.
Old Oct 22, 2001 | 10:45 PM
976's Avatar
976
New User
Default Re: what do I need to pass tech inspection? (00R101)
Some tracks require at least a 3-point harness?
Old Oct 22, 2001 | 11:04 PM
Chris's Avatar
Default Re: what do I need to pass tech inspection? (B21A)
thats a stock seatbelt on post 1980(?) cars...
Old Oct 23, 2001 | 06:47 AM
CivicSiRacer's Avatar
I'll add:
brake has to had feel
no loose body panels (like accidents)
M90 and SA90 will expire at the end of this year
no loose items in your car
a working seat belt
and some place require a working exhaust (no unbolting of your exhaust)
__oversea
Jan 12, 2010 07:51 AM
HondaMan78155
Honda Civic (2001 - 2005)
Sep 19, 2006 06:59 PM
envious1320
Aug 1, 2005 05:38 PM
Splat
Jul 26, 2002 10:08 AM
OneThirtyEight
Sep 7, 2001 08:31 AM
