what fuse or relay did i blow?
Old Mar 21, 2004 | 01:55 AM
94SiHatch's Avatar
Default what fuse or relay did i blow?
Well, the car wont start.
i forgot to disconnect the ground wire from the battery when taking off the starter, and the main feed grounded.
now when I turn the key to run, there is no fuel pump, and when i turn to start, there is still nothing.
i have checked the fuses, what relays might I have fried? I still have power to the chassis, just nothing in the motor I think.
Old Mar 21, 2004 | 02:23 AM
IWearMyKswiss's Avatar
New User
Default Re: what fuse or relay did i blow? (94SiHatch)
did you check all the fuses under the hood? its so late right now and i cant think of the fuse under the hood that you probably blew,..but yea,..check the fuse box under the hood
Old Mar 21, 2004 | 04:05 AM
94SiHatch's Avatar
Default Re: what fuse or relay did i blow? (2.0 EK)
I found it. Cut the insulation of a couple wires when i was re-routing the o2 sensor for my header.
Old Mar 21, 2004 | 07:34 AM
WalkingKenshin
Guest
Posts: n/a
lol.. you gotta be more carefull when working on your car bro. Right tools for the job lad.
Old Nov 8, 2004 | 11:40 PM
integramic's Avatar
Default Re: what fuse or relay did i blow? (WalkingKenshin)
Have the same problem. Lights come on in the dash. turn key and nothing. I can hook up a bypass at the starter and it will start but because the fuel pump isn't working it turns back off. Not my car. I got it in pieces and am trying to help a guy out. Has an ls in it. Not sure of any of the wiring because I didn't do it. But he said it was working fine when he left from the last shop.
Old Nov 9, 2004 | 08:04 AM
integramic's Avatar
Default Re: what fuse or relay did i blow? (integramic)
I checked the srr, and acc fuses. They both have power. I am not getting a starter signal at the fuse(yes I checked the fuse). I changed out the main relay also. Still nothing.
jimmy051702
Jul 9, 2011 04:32 PM
Dc295kid
Jan 1, 2011 04:47 PM
CRX_RR
21
Jun 17, 2008 08:16 PM
TurboFryBox
Apr 2, 2003 01:42 AM
jaje
Jun 14, 2002 01:07 PM
