h22 balance shafts?
Old Mar 20, 2004 | 07:03 PM
h22 civic's Avatar
Default h22 balance shafts,egr?
remove or not to remove that is the question pros and cons turbo car shooting for 600 whp and occasionally street driven when i catch a suker
Old Mar 20, 2004 | 07:07 PM
LudeyKrus's Avatar
For a turbo car, I honestly wouldn't bother w/ removing them.
They have been dyno'd to give about 3-4 HP throughout the RPM range, but supposedly they make it rev quicker b/c of the reduced rotating mass.
It will make the car vibrate a bit more; if you're turbo, you should just up the boost a pound to compensate. In an n/a car, every HP counts.
Old Mar 20, 2004 | 08:49 PM
h22 civic's Avatar
Default Re: (LudeyKrus)
Old Mar 21, 2004 | 12:35 AM
MPower332TI's Avatar
Default Re: (h22 civic)
I would ditch them for the simple fact of simplifing things.
Old Mar 21, 2004 | 07:42 AM
1700anddroping's Avatar
Default Re: h22 balance shafts,egr? (h22 civic)
i have a h22 stroked to a 2.4L.not that that matters?but i do not run the balance shafts and i am turboed.all they do is keep grandma's *** from shaking at a red light.i my self blocked off the oil passeges leading to the balance shafts and took them completely out."not that you have to".
h22 stroked to a 2.4L w/ xs t67 bb w/ pro race fogger system.
Old Mar 21, 2004 | 07:52 AM
Kal's Avatar
Kal
Default Re: h22 balance shafts,egr? (1700anddroping)
if you feel like having your car shake a lot, remove it
Old Mar 21, 2004 | 08:12 AM
Default Re: h22 balance shafts,egr? (Kal)
well i wouldn't say alot.but yes you feel a little? but no worse than the motor mounts you use in a swap.
Old Mar 21, 2004 | 08:47 AM
h22 civic's Avatar
im noty worrid bout the car shaking a little.im more interested in is it good or bad for the motor it self ive heard mix reactions especially with the h22 broken cranks,also if i do remove them what dampener do ya recomend
Old Mar 21, 2004 | 10:11 AM
i have never had any problems? i am running a ud crank pulley .but you could just run your stock and you will be fine .good luck on your set up.
Old Mar 21, 2004 | 10:25 AM
LudeyKrus's Avatar
I don't really think there are any long-term side effects to your motor, and I have never heard of a snapped H22 crank from runnin no balancer shafts.
If you think that the extra shaking is worth the extra ~4 HP, then go ahead.
Old Mar 21, 2004 | 10:32 AM
i made 10 hp on my last h22 i dynoed .now as far as being worth it? it depends on how hp hungery you are every little bit counts.on my set up now yes it is worth it.but i don't drive it everyday.but to some one that drove it every day? different strokes for different folks.but i do understand your point.
Old Mar 25, 2004 | 03:59 PM
h22 civic's Avatar
Default Re: (1700anddroping)
Old Mar 25, 2004 | 06:54 PM
sikcrx80's Avatar
got a friend who did.. make a short story short he put them back on. vibration
civtic
48
Feb 11, 2008 07:47 PM
nekoabandoned
Jun 3, 2006 11:01 PM
pentaq
Jul 31, 2005 08:41 AM
95accordh22a
Mar 8, 2005 07:11 PM
96grnaccord
Jul 28, 2002 08:32 PM
