D series tranny removal
Old Mar 20, 2004 | 04:39 PM
specktur's Avatar
Default D series tranny removal
I can't find my haynes manual and I'm pissed about it... ANYWAY...
I am trying to take the tranny off of the engine I have in my garage. I have taken off about 6 bolts so far, 3 go from the tranny and thread into the block (17 mm bolts) one threads into the tranny (also a 17 mm) and two that are on the bottom (15 mm they look like supports).
I can't seem to get the tranny to budge. What am I missing? Any help would be appreciated.
Thanks.
Old Mar 20, 2004 | 04:42 PM
ZUL8R's Avatar
Default Re: D series tranny removal (specktur)
did you remove the starter??
Old Mar 20, 2004 | 05:41 PM
The Internet Tough Guy's Avatar
Default Re: D series tranny removal (ZUL8R)
this should help you out: https://honda-tech.com/zerothread?id=596873
since you've lost your haynes manual, go to http://www.helminc.com - buy one, it will be $70 very very well spent. i'm reading mine cover to cover right now
Old Mar 20, 2004 | 05:54 PM
Fred n J_v2.0's Avatar
Make sure you remove the starter bolts and the bolts holding the black metal flywheel cover. Should be 2 10mm and 2 12mm.
Old Mar 20, 2004 | 06:26 PM
AL ASPIRATED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specktur &raquo;</TD></TR><TR><TD CLASS="quote">I can't find my haynes manual and I'm pissed about it... ANYWAY...
Thanks.
15mm????? i dont think theres any 15mm on hondas
Old Mar 20, 2004 | 09:48 PM
specktur's Avatar
Default Re: D series tranny removal (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">this should help you out: https://honda-tech.com/zerothread?id=596873
since you've lost your haynes manual, go to http://www.helminc.com - buy one, it will be $70 very very well spent. i'm reading mine cover to cover right now </TD></TR></TABLE>
Thanks for the link to the H-T thread. I have a chiltons manual (Not quite as good as haynes, but hey it works), but we just moved and my wife prolly misplaced it on purpose know what I mean. I was just too lazy to dig through all of the boxes.. Thanks for all of the speedy replies.
Old Mar 20, 2004 | 11:32 PM
H22A EG6's Avatar
wiggel that **** and pry it off with 2 flat heads
oh did i mention wiggel
Old Mar 22, 2004 | 03:17 PM
specktur's Avatar
Default Re: D series tranny removal (H22A EG6)
Thanks for all of the help, I got it off today after I removed the starter and the inspection plate. Then I added a little of the wiggle, that worked... Now on to the clutch and flywheel... Anyone know the size of the bolts there, they look like 12 pt sockets am I right?
Sean
Old Mar 22, 2004 | 04:09 PM
Jmunk's Avatar
Pressure plate = 12pt. 10mm
Flywheel = 17mm 12 pt.
Old Mar 22, 2004 | 04:10 PM
dpw41285's Avatar
Default Re: (Jmunk)
are hidden bolts coming from the oil filter side, like on the accords??
Old Mar 22, 2004 | 04:44 PM
specktur's Avatar
Default Re: (Jmunk)
I got em' thanks for all the help.
navin
Mar 26, 2019 11:14 AM
SC-MK1
May 31, 2005 10:44 AM
Ben_si
10
May 3, 2005 08:33 AM
triggerX
Apr 24, 2004 12:03 AM
navin
Mar 18, 2002 11:28 AM
