H22 Air/Fuel Ratio
Old Mar 20, 2004 | 03:08 PM
slim9300's Avatar
Default H22 Air/Fuel Ratio
OK, I have my turbo setup 95% pieced together for my H22 and I am just waiting on my PLX M-300 wideband O2 that I ordered a couple days ago. But here is my question... What Air/Fuel ratio will be safe to run on a stock H22 bottom end on .45 bar (6.5 lbs.) boost? I know that it varies by RPM range, but is there a previous thread that would be helpful that I missed? I have read quite a few threads on this topic, but they just made my confusion greater. I origionally thought that a Air/Fuel ratio of 16.0-15.5 was ideal and safe, but now I am seeing H22 people running 12.0-13.0? WTF, isn't that hella rich? Please help, anything would be appreciated.
Old Mar 21, 2004 | 12:57 PM
slim9300's Avatar
Default Re: H22 Air/Fuel Ratio (slim9300)
Please?
Old Mar 21, 2004 | 01:09 PM
Jared's Avatar
about 11.5 to be safe
Old Mar 21, 2004 | 01:26 PM
Mase's Avatar
Default Re: H22 Air/Fuel Ratio (Jared)
you should take efi101 you'll learn all you need to know
Old Mar 21, 2004 | 01:51 PM
slim9300's Avatar
Default Re: H22 Air/Fuel Ratio (Mase)
This may be a stupid question, but HOW? Maybe I will try a search...
Old Mar 21, 2004 | 06:11 PM
slim9300's Avatar
Bump
Old Mar 21, 2004 | 09:07 PM
kpt4321's Avatar
Bumping is annoying man. Sorry, but yeah...
Ok. About the question:
The proper A/F ratio is mainly determined by two things: the setup, and the amount of load on the motor. Obviously you specified the load, and you are only interested in the A/F ratio at full throttle.
So, you have to decide what the proper A/F ratio is for you. The A/F ratio for best power is 12.5:1, but not many cars will be able to safetly run that on pump gas. You usually need to run richer to keep the car from knocking.
Ten's or lower 11's usually work well on pump gas, as a starting point.
Old Mar 21, 2004 | 09:36 PM
slim9300's Avatar
Default Re: (kpt4321)
Sorry, but it's the only way to get my question answered.
And thanks alot for your help, it was by far the best response I have gotten anywhere.
Do you know of any sources that would be helpful to Air/Fuel ratios and tuning?
Old Mar 21, 2004 | 10:27 PM
quick_DC5's Avatar
15.0 to 16.0 thats hella lean and unsafe. You might wanna try 12.5 to 13.0 max.
94_accordVTEC
Nov 27, 2005 08:25 PM
Honda_Tengoku
Jul 23, 2004 12:30 PM
