quick question w/ pic. dowel location
Old Mar 20, 2004 | 07:53 AM
lsvtec101's Avatar
Default quick question w/ pic. dowel location
just wanted to double check i have the dowel pins in the right place. exhaust side right?
http://www.we-todd-did-racing....D.jpg
Modified by aemcivic_02917 at 12:11 PM 3/20/2004
Old Mar 20, 2004 | 09:44 AM
zensoku207's Avatar
correct. they could really be put anywhere, as they are just for alignment. clean block tho
Old Mar 20, 2004 | 11:10 AM
lsvtec101's Avatar
Default Re: (zensoku207)
thanks
Old Mar 20, 2004 | 09:38 PM
JDMorgan's Avatar
can you do 4 corner holes? that would make the most sense, right?
Old Mar 21, 2004 | 09:26 AM
zensoku207's Avatar
Sure, it could be done, but I think there are only 2 holes that dowel pins can fit in....may be different with some blocks, but the other two would have to be enlarged for the others.
Old Mar 21, 2004 | 01:47 PM
Se-rv-Tak's Avatar
Take a b20-vtec for instance. The b20 I believe is on the exhaust side, and the b16 Head is on the intake side. or visa versa... all I know is that they are on different sides.
Old Mar 22, 2004 | 06:00 AM
JDMorgan's Avatar
would using 4 dowels do any good? dowels are cheap from honda right?
Old Mar 22, 2004 | 05:27 PM
zensoku207's Avatar
Just get head studs....instant alignment.....thats all dowels are for. technically you could build a motor without them.
Old Mar 22, 2004 | 05:38 PM
onePOINTsix's Avatar
awsome looking block dude, if you did all that work keep up the good work
Old Mar 23, 2004 | 06:22 PM
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">Just get head studs....instant alignment.....thats all dowels are for. technically you could build a motor without them.</TD></TR></TABLE>
the head can still move a lil bit on the studs. dowels can only help, right?
Old Mar 23, 2004 | 07:33 PM
sander's Avatar
2.7(p/t)
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">would using 4 dowels do any good? dowels are cheap from honda right? </TD></TR></TABLE>
This would not work. There are properly sized holes on The exaust side for vtec heads and the intake side for non vtec head. You can not use 4 dowels on the head. There is no purpose for that anyway.
-sander
B20VSi2000
May 7, 2016 11:53 AM
Civic_Bitch
Apr 4, 2006 09:08 PM
turbo Si
Nov 1, 2005 04:37 AM
rafael_dias
Jan 20, 2005 04:38 PM
lsvtec101
Mar 20, 2004 09:22 AM
