no movement!?
Old Mar 19, 2004 | 07:25 AM
iwhichisme's Avatar
Default no movement!?
Hey guys, I have a freind who just swapped a jdm h22 into his 91 accord. The motor is a 92-95 h22. He is currently using the original sohc tranny that came with the car. By the way it is a automatic. Anyways, it "the tranny" was running fine before the swap, but after the swap he has not been able to move the car. The tranny fluid was drained and replaced. Our local honda repair shop says that he needs to replace the tranny with a jdm one, and to buy one and have it put in would run 1600. Im assuming he should be able to use the original tranny that came in his car. The motor runs just fine, no issues there.
If you guys have ever had this issue or know a solution. please help us out. I dont know dittilly **** about accords, or automatics, as i am a eg guy myself.
chazz
Old Mar 19, 2004 | 05:49 PM
iwhichisme's Avatar
Default Re: no movement!? (iwhichisme)
evening bump, c'mon guys im sure someone has been through something similar.
Old Mar 19, 2004 | 06:20 PM
InjectedPerformance's Avatar
We sell parts.
Maybe the torque converter is binding. Did you put the torque converter on the tranny first? Then the tranny along with torque converter to the motor. If you dod not do this the pump will fail.
Old Mar 21, 2004 | 06:36 AM
iwhichisme's Avatar
Default Re: no movement!? (primo8998)
im not sure if that was an issure or not, as i was not there during the swap. Ill check with him to make they did do that correctly.
StockDC2
Aug 21, 2008 02:49 PM
iwhichisme
Mar 21, 2004 02:44 PM
juicedh22
Aug 6, 2003 08:37 PM
