stiffer crx's
Old Mar 18, 2004 | 08:56 PM
geniusanthony's Avatar
Default stiffer crx's
has an one used closed cell polyurethane expanding foam on their crx's in the nooks between the body and frame e.g. in the hatch area to stiffen te car and stop squeaks. supposedly a 2-4 lb density will do wonders...
Old Mar 18, 2004 | 09:05 PM
^jefs0ng's Avatar
Banned
Never heard of this; hope someone can shed some light
Old Mar 18, 2004 | 09:06 PM
CyniKal.Mindset's Avatar
Default Re: (^jefs0ng)
I just use a rear floor bar along with the strut tower bars and I have no squeeks, rattles or shakes in my civic
Old Mar 18, 2004 | 10:31 PM
Lo-Buck EF's Avatar
Default Re: (CyniKal.Mindset)
put in a roll bar. it will make for interesting driveway teetering antics
Old Mar 18, 2004 | 11:44 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: (Lo-Buck EF)
you are talking about high density foam that you mix and pour into cavities of the car, increasing the structure and quieting the panels. very worth while but somewhat expensive and messy. it is a must do on my list of things.
Here is some info
https://honda-tech.com/zerothread?id=616530
stan
P.S. read your post over... definately consider higher density readings than 4.
about 40-60 is more like it.
Old Mar 18, 2004 | 11:54 PM
B2FiNiTY's Avatar
Default Re: (Stan D)
Rear reinforment bars definately tie up the chasis better and prevent such squeeks.
Old Mar 19, 2004 | 12:00 AM
Default Re: (B2FiNiTY)
my "reinforcement" bars in the back provide a horizontal surface to put my drying laundry. they do not do anything for handling or structural integrity of the car. foaming is an old trick, used my BMW owners and "boxes" in the otherwise moving tack-welded panels.
stan
JL_DC5
Jan 10, 2009 06:20 PM
sean555
11
Feb 19, 2006 07:17 PM
SpeedDemonAaron
Aug 17, 2004 11:20 AM
Tad
Oct 7, 2003 12:54 AM
Creepshow S60
Aug 6, 2003 05:04 PM
