ACT CLUTCHES...whose familiar...?
Old Mar 18, 2004 | 08:52 PM
ChillOutWayne's Avatar
Default ACT CLUTCHES...whose familiar...?
Ok heres the deal. My buddy has an Si, he bought it like a year ago with this tough *** clutch in it, and he hated it, especially since his car was stock. Anyway im going turbo soon and we decided to swap clutches, i got a good deal on a brand new stock replacement for like 120 for the kit, so i bought him that to trade with the one he had. So today we swap out his and it turns out it is an ACT. Anyway heres where the question comes in, on the Pressure Plate i see the number H015X. Now i believe this is an Extreme pressure plate, but how does this strength compare to the Heavy duty one? Also the disk looks stock and has a little crown symbol and says NKK on it i believe, and i think thats stock. Anyway anyone know the info on that pressure plate, all i could find was H025X's for sale, and i was wondering if maybe this one was cheaper/weaker. Thanx guys, also wat disk would u recommend, for a GSR on 8psi lookin for like 250WHP, not sure about the torque (even tho i know thats what matters), should i run wats in there, it looks like its still got some meat, or upgrade to a ACT street strip? Thanx alot guys, i know this is long but im pretty confused. Thanx again
Dan
Old Mar 18, 2004 | 09:55 PM
3RdT's Avatar
Default Re: ACT CLUTCHES...whose familiar...? (ChillOutWayne)
i had a xtrem pp and a street organic clutch, my clutch leg is hella stronger now haha. that pressure plate is really stiff and it grips pretty good. i recommend gettin a xtreme pp and street/strip. and heres tha act if u need info http://www.advancedclutch.com/
Old Mar 18, 2004 | 10:36 PM
rxse7n
Guest
Posts: n/a
Default Re: ACT CLUTCHES...whose familiar...? (3RdT)
I cannot stand the xtreme pressure plate. What I was running on my 2.2 turbo around 12psi was the ACT 6-Puck disk and the heavy duty pressure plate. It never slipped once and it was very streetable. It was my favorite clutch that I have ever used, and that is what will go on my eg in the near future. Good luck.
Old Mar 18, 2004 | 11:35 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: ACT CLUTCHES...whose familiar...? (rxse7n)
I f i remember correctly the extreme has more fingers on the pressure plate. The extreme is a nice pressure plate, i believe 30% pressure increase. I would take that plate and use a stock disc.
Old Mar 19, 2004 | 05:08 AM
Default Re: ACT CLUTCHES...whose familiar...? (primo8998)
Thanx for the replies guys, anyone familiar with that brand on the disk, NKK with the little crown, is that stock? I think im gonna run this setup for now, then if i have problems with this disk, ill go with a SS, wat u guys think? I can get that disk by itself right?
thanx again
Dan
Old Mar 19, 2004 | 09:45 AM
colt45.5's Avatar
Thats an act xtreme.
You could always order a new disc for like 100-120 bucks. Get the street strip disc with copper shavings in it.
6puck ACT is overkill unless your making st00pid power. Its unsprung and VERY abrasive towards the flywheel and pressure plate area.
The clutch you have, i seen used for over a year with 300+ whp and NO problems
Im sure there are people out there who have had probs tho. It depends on driver. and a common problem is imput bearings with a clutch that grabs well and a higher milage trans.
Old Mar 19, 2004 | 08:48 PM
Default Re: ACT CLUTCHES...whose familiar...? (colt45)
Ok great, thanx for the replies guys. One more question for now, as far as the part number being H015x, and the new ones being H025x, obviously its an older model, are there any differences? also is anyone running this older one?
Thanx again
Dan
Old Mar 20, 2004 | 01:07 AM
visi0n's Avatar
act pair's huge clamping force with organic disks which i'm not a fan of.
it'll work fine for your applicatino though. stiff *** pedal though!
Old Mar 20, 2004 | 07:47 AM
Default Re: (visi0n)
Yea the pedal in my buddies Si was just outta control. It will be intersting to see how it feels in mine, although im sure it will be the same. Oh well, its worth it knowing it will hold the power. Thanx
Dan
Old Mar 20, 2004 | 11:54 AM
Sliced Beard's Avatar
Default Re: (ChillOutWayne)
i can sell you a Pro Clutch six puck disk for 170 shipped if you want one
i can either get it in sprung or un sprung
Old Mar 21, 2004 | 08:17 PM
Default Re: (dirtyd463)
Thanx man, ill keep u in mind...and thanx for the replies guys..
Dan
Absentmind
Jun 23, 2004 08:53 PM
SofaKing
Sep 23, 2003 12:41 PM
chingchong
Mar 30, 2003 09:18 PM
TurBoXBirD16
Jun 21, 2002 11:51 PM
