Aligmnent question
Old Mar 18, 2004 | 08:46 PM
metal-x's Avatar
Default Aligmnent question
Do you guys do a 4 wheel alignment on your ARR's?
or would just the fronts be ok....
Old Mar 18, 2004 | 08:53 PM
nEoMuGen's Avatar
Default Re: Aligmnent question (metal-x)
Are there 2 wheel alignments out there?
Old Mar 18, 2004 | 09:08 PM
bus stop's Avatar
Default Re: Aligmnent question (nEoMuGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">Are there 2 wheel alignments out there?
Yes
Old Mar 18, 2004 | 09:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Aligmnent question (whOsEvO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whOsEvO &raquo;</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
shops will supposedly perform a "two-wheel" alignment, but that's not the proper way to do an alignment. To properly align the car (set the toe) you have to align the rear wheels first, and then the fronts are aligned off the rears. If you watch a car being aligned with the sensors attached to the wheels, when the rear wheels are adjusted, the readings for the front wheels will actually change. So always have a 4-wheel alignment done.
Old Mar 18, 2004 | 09:39 PM
EG TYPE-R's Avatar
Default Re: Aligmnent question (PatrickGSR94)
i do alignments for the shop that i work for and we only do 4wheel alignments. like the other guy said the front is based off of the rear tires. that angle is called the thrust angle or thrust line and basically is the direction that the rear points. if the rear is not pointed in the proper direction your car can dog track which means that the rear will be slightly off from the front and will look like the car is going sideways down the road.
hope that helped
misha
Old Mar 18, 2004 | 10:38 PM
metal-x's Avatar
Default Re: Aligmnent question (EG TYPE-R)
thanks for the info guys
G2_Fella
Oct 8, 2006 08:02 PM
return_2020
Honda Civic (2001 - 2005)
Aug 28, 2006 06:29 AM
compprat
May 14, 2006 06:01 AM
130R
Oct 13, 2004 10:56 AM
DsCivicEx
15
Jan 9, 2004 08:38 PM
