Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Wheel Allignment
Old Aug 27, 2006 | 05:36 PM
return_2020's Avatar
Default Wheel Allignment
03 civic. i just got new tires(195/60/15) and also got allignment done, car drives perfect, but when i looked at the wheels closely i found rear wheels to be leanning inside a little bit from top. Is this normal or i should get it checked it out again ? Pleas advise.
|--------| (Front)
/--------\ (Back)
Old Aug 27, 2006 | 05:47 PM
Miracle's Avatar
Default Re: Wheel Allignment (return_2020)
Take it back and have them do it right. Or go somewhere else.
Old Aug 27, 2006 | 06:53 PM
ES2's Avatar
ES2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by return_2020 &raquo;</TD></TR><TR><TD CLASS="quote">03 civic. i just got new tires(195/60/15) and also got allignment done, car drives perfect, but when i looked at the wheels closely i found rear wheels to be leanning inside a little bit from top. Is this normal or i should get it checked it out again ? Pleas advise.
|--------| (Front)
/--------\ (Back)</TD></TR></TABLE>
Our cars are set with about 0 camber up front and 0.5 in the back, with toe as close to 0 as possible. Go back to your alignment guy and ask if he has a print out of your alignment.
+/- 0.25 degree variation in camber should be within spec. Again, toe should be as close to 0 as possible.
Old Aug 28, 2006 | 06:29 AM
03EM2guy's Avatar
Default Re: Wheel Allignment (ES2)
have you lowered your car?
SPC camber kit.
same thing happened to me i had to go to 3 diff shops to get mine done right
fisherman
Honda Civic (2006 - 2015)
Jul 27, 2008 11:31 AM
EdoMoto
17
Jul 12, 2008 04:41 PM
SpeedoKing
10
Jul 13, 2007 06:53 PM
metal-x
Mar 18, 2004 10:38 PM
VTEConly
May 27, 2003 03:09 PM
