Can a busted outer cv boot cause...
Old Oct 20, 2001 | 05:55 PM
myNAteq's Avatar
New User
Default Can a busted outer cv boot cause...
I jsut had my new axles installed and rotors and 30minutes down the freeway and my car starts to veer left a little, then really hard and smoke starts coming from under. The car started shaking and I pulled over and I checked and my outer driver's side CV boot came loose and all the grease was everywhere. But then I tried to get in gear and the car wouldn't go anywhere. I mean it shifts into all gears, but then it doesn't engage or something.
Damn this car. Any ideas?????
Old Oct 20, 2001 | 06:13 PM
Turbohatch's Avatar
New User
Default Re: Can a busted outer cv boot cause... (myNAteq)
what happend was the the axle shaft for your power wheel came out of the tranny. Replace the cv boot and push the axle back into the tranny... it has happenend to me before to worry not a big problem.
Old Oct 21, 2001 | 02:37 PM
non-VTEC's Avatar
maybe all the grease came out and the bearings in the joint seized?
that's really strange...........
Old Oct 21, 2001 | 07:44 PM
BreakStuff's Avatar
New User
Default Re: Can a busted outer cv boot cause... (Turbohatch)
Yep, sounds like thats what happened.. too bad it wasted the new axle boots, could have been the wrong size axle that was installed causing the axle to pull away from the CV joint..
GSR936
Feb 26, 2009 02:59 PM
B16b-EJ8
16
Jan 9, 2007 06:01 AM
civicqm
Feb 24, 2004 06:16 PM
Simple
Feb 1, 2004 02:46 PM
leadfoot78
May 26, 2003 12:17 PM
