Zex nitrous, B-series CM lightened Flywheel, Drag Turbo Manifold
Guest
Posts: n/a
I'm moving out of my house very soon so I need to get rid of this stuff quick.
Selling a Drag turbo manifold, that is cracked but then welded.
It was working fine when I removed it to upgrade to a different manifold setup.
I taped a hole on the 4th runner for a egt gauge(I know it wasn't the best spot)
You can use it for an egt gauge or simply just plug it up with a screw/plug.
90 + shipping takes it.
Clutchmaster Lightened Flywheel. I'm selling this for a friend because he turned his car back to stock and parted everything out. Was working fine when removed.
It has a disc surface which is interchangable so you could either have it resurfaced, reuse it how it is, or get a new one and basically have a new flywheel.
No chipped teeth and works fine.
145 + shipping
Zex nitrous Kit. This kit was only used 3 bottles and still has half a bottle in the tank. Comes with all the necessary stuff except the vacuum hoses which you can get at any auto parts store. Also included is the Zex pressure gauge which cost me 50 bucks. Works excellent and in very good condition.
$325.00 + shipping takes it.
PM me if your interested.
Modified by David555 at 10:56 PM 3/18/2004
145 + shipping
Does the nitrous kit come with the box, manuals, etc.? Is it a dry or wet kit? What jets does it come with? Also, how much for shipping to Colorado, 80129?
ATS*Mark
25
Mar 22, 2004 10:06 PM
