act prolite or streetlite flywheel??
OG triple OG
sup guys , im trying to decide which flywheel to get for my y8 turbo setup , which would benifit me more . the car is a street/drag/road race car.
Re: act prolite or streetlite flywheel?? (Hella_JDM)
for drag DONT get the prolite. Your 60ft times will go to hell. It is so hard to launch on a very light flywheeL. Basicly you rev to 6k, then as soon as you let go, your RPMS drop to 3.
streetlite over prolite; its a little heavier and will be eaiser to drive on and will keep you in boost longer while shifting than a prolite. i dont know much about the zex, but whatever one you get, be weary of aluminum (they can warp) and anything too light cause you're running a turbo
Re: act prolite or streetlite flywheel?? (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol »</TD></TR><TR><TD CLASS="quote">for drag DONT get the prolite. Your 60ft times will go to hell. It is so hard to launch on a very light flywheeL. Basicly you rev to 6k, then as soon as you let go, your RPMS drop to 3.</TD></TR></TABLE>
there must be something wrong with the way you are launching, i can pull off 2.2s on street tires in an acccord with an 8.5lb flywheel.
If your rpms drop that low, then your bogging, not cuz the flywheel is too light.
Though you are right about lighter flywheels being not too much use in a drag environment, but they come in soo damn handy when you rev matching downshifts, and heel toe through a corner,
OG triple OG
Re: act prolite or streetlite flywheel?? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">try using a COMPTECH flywheel. </TD></TR></TABLE>
D sereies owns me
D sereies owns me
i have the prolite and i can chirp 3rd, of course the SRR 4.7final drive helps.
when i had a 10.5lb flywheel(stock final drive) there was no difference in shifting hard from 1st to 2nd between it and the stock 18lb one, both resulted in a little chirp. so the decrease in inertia of the lighter flywheel didnt impact much.
i say the main thing to consider is, the lighter the flywheel the more likely you'll get vibrations at idle, but even that can be remedied by increasing the idle rpm.
Re: act prolite or streetlite flywheel?? (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">Though you are right about lighter flywheels being not too much use in a drag environment, but they come in soo damn handy when you rev matching downshifts, and heel toe through a corner, </TD></TR></TABLE>
I tottally agree, I don't even really go to the tracks that much, its all about autocross and road courses for me. My street lite loves that.
Prolite used in my car. Pulls 1.62 60" Love it.
go streetlite. Going too light will affect your daily driving too much. Rpms will drop off too fast almost stalling when coming to a stop. Plus you wanna keep you're motor at higher rpms to save your boost. Naw mean????
Re: act prolite or streetlite flywheel?? (zseeanz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz »</TD></TR><TR><TD CLASS="quote">go streetlite. Going too light will affect your daily driving too much. Rpms will drop off too fast almost stalling when coming to a stop. Plus you wanna keep you're motor at higher rpms to save your boost. Naw mean????</TD></TR></TABLE>
spoken like someone who has real experience with it
Re: act prolite or streetlite flywheel?? (AzCivic1.6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCivic1.6 »</TD></TR><TR><TD CLASS="quote">
spoken like someone who has real experience with it </TD></TR></TABLE> We don't need your sarcasm thanx for playing though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCivic1.6 »</TD></TR><TR><TD CLASS="quote">then stop giving bs opinions on something you obviously have no experience with.</TD></TR></TABLE>Spoken like a true *******
I have a Fidanza fly wheel and love it. Tried a friends Unorthodox fly wheel and didnt really like it. i think the fidanza has a way better construction and seems more solid than the unorthodox. just thought id post this to give you a wider range of options
in my old ef i had a prolite...i was satisfied with it at the track i pulled off 2.027 60 ft best time was 14.808
id say go with the prolite since your going to make you car an all around car ya know
I couldn't tell the difference between the two.. Not enough to make a difference in every day driving at least and I live in the bay area and there are plenty of hills.
Re: (fishnfst)
i have an exedy 8.5lb in my hatch
given it is not turbo but i definately felt a difference.
i would think a 11-13lb flywheel would be best suited for boost because you dont want your engine to fall out of boost between shifts, which WILL happen if you have too light of a flywheel.
just my opinion and i will say this I LOVE MY EXEDY FLYWHEEL
