89-91 CRX Si wheels on a 94 EX
Old Mar 18, 2004 | 02:25 AM
mycivicstoo(s)low's Avatar
Default 89-91 CRX Si wheels on a 94 EX
I have a set of CRX Si wheels that I desperately need to put on my 94 Civic EX. After searching numerous times, I've discovered that I need to either buy spacers or shave down my brake caliper brackets just a little. Since I'm broke and can't afford spacers or extended wheel studs, I'll be shaving the caliper bracket a bit.
My question is: How much shaving do I need to do, and will a rotary tool (Dremel, etc.) do the trick? Obviously, I'll mess with it until the wheels fit, but I want to be sure I have the correct tools before I start messing with it. Thanks for the responses if I get any.
Edit: 90-91 wheels, my mistake.
Modified by mycivicstoo(s)low at 1:06 AM 3/21/2004
Old Mar 18, 2004 | 11:53 AM
Default Re: 89-91 CRX Si wheels on a 94 EX (mycivicstoo(s)low)
Old Mar 19, 2004 | 05:39 AM
Anybody?
Old Mar 20, 2004 | 01:17 PM
last bump
Old Mar 20, 2004 | 01:31 PM
KillerEJ's Avatar
i believe they will fit with no problem if you have NO ABS....(9.6in.) if your ex does have ABS (10.3 in.) then I just wouldn't put them on.
Old Mar 20, 2004 | 02:48 PM
Default Re: (KillerEJ)
94 and 95 EXs without ABS had 10.3" rotors. I don't have ABS, but I do have the larger brakes, so that's my problem. I wish it was as simple as just getting different wheels, but that's not an option for me right now.
Old Mar 20, 2004 | 02:56 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (mycivicstoo(s)low)
they fit over the 10 inch rotors no problem without ANY spacers.
I was running some 88 CRX Si wheels on the snow for a couple months over my stock Teg brakes up front. Friend of mine rolled them awhile with his 94 EX also. No shaving/spacers needed.
HX wheels are a different story, because the spokes are not far enough away from the caliper
Old Mar 20, 2004 | 02:57 PM
Default Re: (Emerika)
Well dammit I did a test fit and they rubbed something. I'll try again.
Old Mar 20, 2004 | 02:58 PM
Evs-One's Avatar
Solbros Owns Me
*shrug*
Even had them on my friends 99 GSR also
Old Mar 20, 2004 | 03:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">*shrug*
Even had them on my friends 99 GSR also </TD></TR></TABLE>Cool, maybe I was hearing something else rub. Thanks for sharing your experience.
Old Mar 20, 2004 | 03:04 PM
B2FiNiTY's Avatar
Depends which crx si wheels.
Old Mar 20, 2004 | 03:19 PM
Default Re: 89-91 CRX Si wheels on a 94 EX (B2FiNiTY)
This kind:
Old Mar 20, 2004 | 03:28 PM
Evs-One's Avatar
Solbros Owns Me
those are the 90-91's...we were using 88-89's
Old Mar 20, 2004 | 03:53 PM
dpw41285's Avatar
Default Re: 89-91 CRX Si wheels on a 94 EX (Emerika)
They'll fit, did you have problems putting them on like they were getting stuck?? Any way before you think they are to small tighten them and drive around the block and come back and look for wear signs
Old Mar 20, 2004 | 09:09 PM
Default Re: 89-91 CRX Si wheels on a 94 EX (dpw41285)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">those are the 90-91's...we were using 88-89's</TD></TR></TABLE>I got the years wrong, thanks for clearing that up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpw41285 &raquo;</TD></TR><TR><TD CLASS="quote">Any way before you think they are to small tighten them and drive around the block and come back and look for wear signs</TD></TR></TABLE>I did a test fit and thought I heard a scraping sound when I turned them. I'd rather know if they fit or not before driving on them.
felixr78
Mar 28, 2008 12:32 AM
Surewin
Mar 3, 2005 11:40 AM
rice_classic
13
Feb 25, 2005 08:17 PM
B18C1 '96 Coupe
11
Mar 28, 2004 08:38 PM
y49crxsi
Jan 22, 2004 07:22 AM
