Motor with no vins.. Need help and Advice!!
Old Mar 18, 2004 | 01:04 AM
vboy714's Avatar
Default Motor with no vins.. Need help and Advice!!
i was wondering if anyone knew where i can check a block number on a motor to know if it is legit. the vins are not there and i wanted to know if there was a way to check this.. if so where.. thanks
Old Mar 18, 2004 | 01:09 AM
svtec's Avatar
L D E S
Default Re: Motor with no vins.. Need help and Advice!! (vboy714)
have the state patrol run the block number.
Old Mar 18, 2004 | 02:17 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Motor with no vins.. Need help and Advice!! (svtec)
the block number is right underneath where the engine code is. if it's a 94 or 95 usdm motor it will not come with VIN numbers on it.
Old Mar 18, 2004 | 05:06 AM
RedTegLS's Avatar
Default Re: Motor with no vins.. Need help and Advice!! (AzntaggeR)
There is only one reason to remove the numbers off a motor.........do not buy it!
Old Mar 18, 2004 | 05:22 AM
mr.beeks's Avatar
Default Re: Motor with no vins.. Need help and Advice!! (RedTegLS)
if you had to ask
dont do it!!!
cause you are not confortable with it..
Old Mar 18, 2004 | 05:53 AM
IntEGNYC's Avatar
Default Re: Motor with no vins.. Need help and Advice!! (mr.beeks)
if its too good of a deal, it probably is. dont steal stolen parts.
you seen enough stolen and stripped car threads here to know where the stuff come from...
Extradition
67
Dec 7, 2007 05:45 AM
shtalker
Oct 23, 2005 04:21 AM
allmotor.net
Jun 22, 2004 07:17 AM
WildMan541
Apr 21, 2003 08:45 PM
DubyaAye
Feb 21, 2003 04:12 AM
