how did you guys hook up your amps...
Old Oct 20, 2001 | 08:57 AM
REDMAN1322's Avatar
New User
Default how did you guys hook up your amps...
cause i dont know where to put the wires that connect to the battery through the firewall
or is there another route i can take like the fender
Old Oct 20, 2001 | 09:05 AM
Phat Corolla's Avatar
New User
Default Re: how did you guys hook up your amps... (REDMAN1322)
on the drivers side of the firewall, (under the hood) you will notice that there is a bunch of wires going into the interior. they are inside a rubber grommet type thing. pull the rubber thing out of the firewall and stick your amp wires into it...
It's darn hard to explain...
Old Oct 20, 2001 | 09:21 AM
REDMAN1322's Avatar
New User
Default Re: how did you guys hook up your amps... (Phat GS-R)
why the driver side
Old Oct 20, 2001 | 09:30 AM
Bert's Avatar
The drivers side because that's where the biggest hole is. You pull out the rubber piece with all the wires in it and use something to thread the amp wire through it. I taped the amp wire to a piece of wire clotheshanger. The hardest part is getting the rubber piece back into the whole. I used a couple flathead screwdrivers but an extra set of hands speeds it up.
lee0149
Audio / Security / Video
13
Jan 7, 2009 08:47 PM
Allurian
Aug 8, 2008 09:40 AM
Tegraracer90
Jul 29, 2007 08:03 PM
ChaosUnbound
Jan 17, 2004 07:41 AM
slammmedintegra
Nov 27, 2002 02:11 PM
