Raising compression w/ head gasket
Old Mar 17, 2004 | 04:10 PM
NCcwITR's Avatar
Default Raising compression w/ head gasket
I want a headgasket to raise my compression. Let me see some of your opinions on what and how.. im thinkin Mugen or Spoon... I think i want to go to 12:1..
Old Mar 17, 2004 | 04:12 PM
Misfit's Avatar
Default Re: Raising compression w/ head gasket (NCcwITR)
I didn't know you could go that high with just a head gasket?? I may be wrong...
Old Mar 17, 2004 | 04:16 PM
.RJ's Avatar
.RJ
Mugen gasket = 0.4:1 increase in compression ratio.
This also retards cam timing.... I think each .010" you take off the head/gasket is 1 degree in cam timing as a general reference, but i could be wrong on that number.
Old Mar 17, 2004 | 04:18 PM
jetydosa's Avatar
25 Year Member
Default Re: Raising compression w/ head gasket (.RJ)
A related question, Ive wondered what benefit (if any) would there be raising compression via headgasket in a stock internal typical I/H/E engine?
Old Mar 17, 2004 | 04:19 PM
.RJ's Avatar
.RJ
Default Re: Raising compression w/ head gasket (Jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">A related question, Ive wondered what benefit (if any) would there be raising compression via headgasket in a stock internal typical I/H/E engine?</TD></TR></TABLE>
I'm sure there's some benefit.
But its not worth an afternoon of pulling the head... for me.
Old Mar 17, 2004 | 04:20 PM
NCcwITR's Avatar
i mean.. eventually, want something like 12 1. hehe sorry
Old Mar 18, 2004 | 08:45 AM
mstewar's Avatar
umm.. a bit more power..
i have the mugen gasket..
Old Mar 18, 2004 | 09:42 AM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">This also retards cam timing.... I think each .010" you take off the head/gasket is 1 degree in cam timing as a general reference, but i could be wrong on that number.</TD></TR></TABLE>
Larry at Endyn claims its for every .012", 1 degree retard.
Old Mar 19, 2004 | 07:02 AM
iperez's Avatar
I had the Spoon 2-ply on my ITR and it was definitely NOT worh the hassle.. I gained maybe 5psi per cylinder and the difference was not noticeable at all.. I did not take a dyno measure but my 1/4 mile times were identical to before the gasket ..
What's worse is that the head gasket failed (leaked) about a year later and I had to start all over again .. At least this time, I'm getting the full head job and JUN3 setup
Sooooo, if you just want more power by adding compression, installing a thin head gasket is not the best way to do it ..
Old Mar 19, 2004 | 07:05 AM
MattD@Stoptech's Avatar
Default Re: (iperez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">Sooooo, if you just want more power by adding compression, installing a thin head gasket is not the best way to do it ..</TD></TR></TABLE>
It's a lot simpler than any other way....
Old Mar 19, 2004 | 11:41 AM
StyleTEG's Avatar
Default Re: (El Pollo Diablo)
Why not just mill the head? It does the same thing, and no worries about the increased risk of head gasket failure. The only disadvantage I see compaired to the headgasket is the inability to go back (guess that can be pretty major though).
Old Mar 19, 2004 | 11:42 AM
.RJ's Avatar
.RJ
Default Re: (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">It does the same thing</TD></TR></TABLE>
Yes and no. You can only go so high before you start impacting other things... if you want high compression, tear the motor down.
Old Mar 19, 2004 | 12:02 PM
StyleTEG's Avatar
Default Re: (.RJ)
I should have been more clear, sorry. It does the same thing as a thinner head gasket.
You are removing material in the same area, and you run into the same problem with clearances.
Of course there are more drawbacks with raising compression from that area vs pistons (or anything else like high comp valves), as discussed. (cam retardation, reduced quench area, etc)
Old Mar 19, 2004 | 01:16 PM
iperez's Avatar
Well.. yes, its the simpler way .. but I'm sure you'll agree that higher compression pistons or milled head would be more productive and reliable in the end .. Besides, just the hassle of pulling the head off just to get that extra .04 compression is really not worth it to me .. Believe me, I did it, and I regret it .. But hey, this is just my opinion and personal experience ..
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
petty$rep
Nov 11, 2006 02:20 PM
tek_civic
Nov 8, 2002 10:52 AM
DelsolVtec18
Sep 27, 2001 03:12 PM
