90 Accord Chime location...
Old Mar 17, 2004 | 03:05 PM
Ryan44221's Avatar
Default 90 Accord Chime location...
Hey Guys!
First time poster, long time lurker.....Anyways, i just finished up repairing my 1990 honda accord that had that infamous driver door latch problem and now that i got everything back together, the Seatbelts dont retract and the seatbelt warning light flashes and the chime continuously is going off. Rather than try to chase that problem down (unless anyone knows an easy fix) id rather disconnect the chime and the remove the seatbelt warning light. Problem is, i cant seem to locate the chime. So my question is, does anyone know the chime location?
Old Mar 17, 2004 | 03:12 PM
.bagged's Avatar
Default Re: 90 Accord Chime location... (Ryan44221)
Good first question..You should be able to locate the wire that is connected to the seatbelt that is sending the signal..simply ground this wire and that should do it..
Old Mar 17, 2004 | 04:42 PM
accord91lx's Avatar
Default Re: 90 Accord Chime location... (baGged93aCcord)
chances are the reason its chiming like it is, is because one of the plugs that plugged into the door latch are either unplugged or something... because my old door latch had plugs to it for the seatbelt... so i'd check those plugs... just a thought...
Old Mar 18, 2004 | 04:37 AM
ACCORDianate's Avatar
There's fuses underhood for the entire seatbelt system. One fuse for each side.
As far as the chimes go, there should be something similar to a fuse panel under the dash that also contains your blinker. Refer to a Haynes manual for super-specific details.
Old Mar 18, 2004 | 02:12 PM
SearchBeforeUPost!'s Avatar
Default Re: (ACCORDianate)
it is inside of the control unit under the pasanger's set. You will have to take it out, pry it apart, and yank the buzzer out. If you don't care that your seatbelts don't work anymore, you can just remove this contol unit and keep it out. No buzzing.
My seatbelts did the same thing in my 91. I have a used control unit coming soon, hopefully they will work again.
and welcome to the forum.
drurgirl
Oct 26, 2017 12:33 PM
chiboy162
Nov 15, 2016 07:37 AM
LoSt is BlaCk
Jan 20, 2009 01:37 PM
CMac
Nov 16, 2006 11:33 AM
Dzaccord
Jun 21, 2005 10:06 AM
