HELP! Tranny fluid change!
Anyone run into this problem before? I just drained the fluid thru the drain plug, then I closed it back up...I went to fill it u p thru the filler bolt using a siphon pump...but it immediately spills out...I KNOW it cant be full after that drain...so whats going on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ants »</TD></TR><TR><TD CLASS="quote">Anyone run into this problem before? I just drained the fluid thru the drain plug, then I closed it back up...I went to fill it u p thru the filler bolt using a siphon pump...but it immediately spills out...I KNOW it cant be full after that drain...so whats going on?</TD></TR></TABLE>
fill it thru the dipstick hole like everyone else does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ants »</TD></TR><TR><TD CLASS="quote">You cant...manual doesnt have a dip stick...
About 2 qts came out...</TD></TR></TABLE>
2 qt's should be right :\ usually its 2.5 to refill....
you guys dont have a dipstick? damn how ya check the fluid levels and all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 »</TD></TR><TR><TD CLASS="quote">
you guys dont have a dipstick? damn how ya check the fluid levels and all?</TD></TR></TABLE>
We pull out the fill plug and make sure the oil level is up to the bottom of the hole.
are you filling with the top "checker screw" out? if not air pressure may be keeping the oil from going in... and you are pouring in the tiny little tube up top right? the place whee a dipstick could be, but there is just a rubber cap?
anyway, you just fill until it comes out the top "checker/drain hole"
sohc
sohc
isnt there something to fill it up with inside the engine bay. like something that has a rubber nipple on it. i am not sure but i think thats for the tranny fluid. like a dipstick but not really. becasue i ran into the same problem with a 94 accord
OK pls don't flame me if I ask a dumb question. Are you sure you drained the ATF and not the engine oil? Would explain why the tranny case is still full.
Main way to tell (besides knowing which drain plug to use), is that the crankcase oil is yellow to brown in color, but ATF is reddish.
Slammd Sol
Mar 28, 2004 10:21 AM
