B16A1 Head Gasket Dilema
Old Mar 17, 2004 | 12:25 PM
Mach69's Avatar
Default B16A1 Head Gasket Dilema
I am getting a B16A for my '90 Civic STD. Now, I know I need mounts, shifter linkage, and other stuff. Now, I need to know, the parts I am going to replace are Spark Plugs/Wires, Timing Belt, Water Pump, Alternator Belt, and should I replace the head gasket? What would be a good reason to replace the head gasket? The shop did a compression test on the engine, and it went well, so why should I replace the HG?
Old Mar 17, 2004 | 12:58 PM
CrowerRex's Avatar
Default Re: B16A1 Head Gasket Dilema (Mach69)
The only reason to replace the headgasket would be if you pulled the head to have it refreshed, but since you haven't taken it off and your compression test was good you will be fine.
Old Mar 17, 2004 | 01:00 PM
RobbieG35's Avatar
12 Years Strong
Default Re: B16A1 Head Gasket Dilema (CrowerRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrowerRex &raquo;</TD></TR><TR><TD CLASS="quote">The only reason to replace the headgasket would be if you pulled the head to have it refreshed, but since you haven't taken it off and your compression test was good you will be fine. </TD></TR></TABLE>
I agree, "if it aint broke dont fix it"
Old Mar 17, 2004 | 02:31 PM
crx_88_si's Avatar
Default Re: B16A1 Head Gasket Dilema (HybridHatch88)
you will need DX/Si hubs too.
silvergoose
Honda Civic (2001 - 2005)
May 17, 2014 02:14 PM
kris9
Mar 21, 2010 05:13 AM
G2_Fella
May 20, 2008 08:25 PM
zcmotor
15
Feb 17, 2008 10:57 AM
gsrHB
May 4, 2007 03:38 PM
