Gsr Wiring Harness
Use the harness that came from your car. Convert the DX harness to MPFI (do a search), and purchase and obd0-obd1 conversion harness from blown90hatch
to make things more simple. You will not utilize the injector resistor box if you choose to run the obd1 injectors. You WILL use that gsr harness for plugs such as: The 2 distributor plugs, 4 injectors plugs (if using the obd1 injectors), vtec solenoid plug, oil pressure switch plug, 4 wire o2 plug, ect switch plug, knock sensor plug, and IAB plug for secondaries if you are retaining the gsr manifold. hth
lost password
Oct 17, 2002 05:47 PM
