Do ITRs have a flywheel dust shield?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">There should be a flywheel dust shield.
There is also a tranny brace that is different from gsrs. </TD></TR></TABLE>
The block brace doubles as the dust shield
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">
The block brace doubles as the dust shield</TD></TR></TABLE>
Ok, so its different from b16's and GSR's and LS's, right???
i coulda sworn mine had the black shield then the thicker metal casing that goes over it witth 14mm bolts i think it is . I took the shield off though and just put that other casing thing over it to keep **** out
So number 10 in the picture is what i should have right? I think they jacked me for that piece when my car was in a shop...
Thank u Everybody for ur help...
Mike
http://www.we-todd-did-racing....D.jpg
No dust shield. Only thing i removed was the brace (17mm boltz) and oil pan....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubnine »</TD></TR><TR><TD CLASS="quote">So number 10 in the picture is what i should have right?
</TD></TR></TABLE>yup..
2-17mm bolts + 2-12mm bolts (into the tranny)
2 or 3-12mm bolts (into the bottom of the block)
It is a beefy piece.
i had some sort of dust shield other than that though on mine , i remember taking it off when i did my clutch for the 1st time when i dropped the tranny . i remember it was a bitch to get off too .
it was like a black thin piece of sheet metal that went like between that #10 in the pic and the tranny. like i said , im pretty sure i remember taking it off becuase i remember it was a bitch to get off.
No dust shield on mine, only the alu. stiffener brace. I had a clear view of the back of the flywheel when I took mine off to grind it down to clear my header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">it was like a black thin piece of sheet metal that went like between that #10 in the pic and the tranny. like i said , im pretty sure i remember taking it off becuase i remember it was a bitch to get off. </TD></TR></TABLE>
Someone swapped yours, ITRs came with the aluminum stiffener brace; period.
street_ride14
Sep 2, 2008 02:46 PM
