v-afc question. (no its not where to install or hwo did you set yours) question lol
Old Mar 17, 2004 | 08:52 AM
W.O.P.'s Avatar
Default v-afc question. (no its not where to install or hwo did you set yours) question lol
i was just wondering what the PRS (im guessing pressure) reading is on yours when you not on the gas mine is reading -750ish and at full throttle its +0.15 i have a ls so is this normal? could that be a indication of my compression reading all added up? just wondering. sorry if its a dumb question
Old Mar 17, 2004 | 08:53 AM
FastSS's Avatar
Default Re: v-afc question. (no its not where to install or hwo did you set yours) question lol (dohc VTEC e
I believe that would be manifold preasure... a la map sensor
Old Mar 17, 2004 | 10:32 AM
94gsr4dr's Avatar
if i remember correctly when i was n/a they were in the low 700's and around 0.00 when under WOT
Old Mar 17, 2004 | 10:52 AM
W.O.P.'s Avatar
is it maniflod pressure? and are they good #'s
Old Mar 17, 2004 | 11:19 AM
asubennett's Avatar
yes manifold pressure. You should not be showing anything in the positive unless you are boosting past the map sensor. My readings were always like -560 at idle and -5 to sometimes exactly 0 at full throttle.
Old Mar 17, 2004 | 11:46 AM
AzntaggeR's Avatar
TSPeed Factory
yeah that's what mines at too.
Old Mar 17, 2004 | 12:10 PM
IN VTEC's Avatar
Alright, where are you hiding the turbo?
Old Mar 17, 2004 | 12:43 PM
W.O.P.'s Avatar
i have everything set up right and it goes+0.17 sometimes even to +0.30 what does that mean? how am i getting positive pressure? and is that good or bad?
Old Mar 17, 2004 | 12:56 PM
IN VTEC's Avatar
Yes. It's possible for normally aspirated cars to attain positive manifold pressure. It's due in part to manifold and intake pipe resonances that "supercharge" the manifold.
Old Mar 17, 2004 | 12:57 PM
W.O.P.'s Avatar
so its good?
Old Mar 17, 2004 | 12:59 PM
2G0S0R1's Avatar
New User
If you did the initialization with any accessories(dome lights,fan,stereo,etc) running, then the voltage values could have been stored differently than when your car is running and the alternator is pumping out juice.
I had the same problem, but was only positive by like .5 and when at WOT my throttle percentage was only showing like 97%...
I bought a new battery... turned off car and all accessories after a warmup and then re-initialized the VAFC(2) and it was all normal again.
Could be different with your setup though.
Old Mar 17, 2004 | 03:21 PM
W.O.P.'s Avatar
it was set up correctly and for wot it says 100% im jsut wondering where the positive is comin from. and when i had my car turbo'd i still have my boost guage in and it goes positive a lil there also? whats goin on here?
Old Mar 17, 2004 | 06:46 PM
asubennett's Avatar
Is it an OEM map sensor and has has it been relocated at all from your turbo set up? This may have something to do with it. What ECU are you using, is it an aftermarket throttle body? Do you have the pressure wires from the VAFC hooked up on the correct place on the ECU harness. More specifically you will have one wire that needs to higher than the other from the VAFC to the corresponding wire on the ECU.
Old Mar 17, 2004 | 08:38 PM
W.O.P.'s Avatar
no nothing was relocated and i have the oem throttle body. im pretty sure i connected everything right i wennt out today and double checked. (i installed it this past summer) i im just clueless
Initial_drift
May 18, 2008 07:31 PM
b17eg
13
Oct 19, 2007 01:41 PM
_Endless_
May 16, 2003 06:24 PM
MattD@Stoptech
Dec 31, 2002 09:38 AM
