baro/atmospheric pressure sensor
Re: (b17eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17eg »</TD></TR><TR><TD CLASS="quote">idb??</TD></TR></TABLE>
lol, IDB=In Da Butt
lol, IDB=In Da Butt
Unceasing Measure
Re: (b17eg)
Baro/atmo sensors are referred to as "MAP" around these parts (unless I have no idea what you're asking about) - it stands for "Manifold Absolute Pressure" and it meters fuel based on the pressure reading. It's either attached to your intake manifold, your throttle body or your firewall-via-vacuum-line.
Because I'm unfamiliar with much of the B17's layout, I suggest you have this question moved to Integra, as that bunch will be more likely to have a picture handy to help you out.
All you little ***** better keep out of threads if you're not going to help or there will be consequences.
i believe it is on the passanger side kick panel, u know inside the car to the right of the ecu just below the glove box. funny that u ask though i had bought a DA teg before that threw that code and couldnt find that sensor as well. i then went to the ecu and there was no wires at the pins the schematic showed..... so i just added them and the sensor
Unceasing Measure
Re: (SoCal B18b 4dr)
https://honda-tech.com/zerothread?id=1390914
It would seem that it's integrated into the ECU and inaccessible. Interesting that there are two atmospheric pressure sensors...learn something new every day!
ah i see, that explains y i couldnt find it on my da, but was able to find it on my crx, i am assuming that the teg's had it in the ecu and i hooked up my crx ecu to the teg and got the code, lol, wish that info was around when i had that problem, woulda saved me quite a bit of time
same prob with D15b2
Im having the same problem with my D15b2. My ecu is flashin 13 and I cant find that damn sensor anywhere. Yes it will have a negative effect on your motor your mileage will go to hell. Im getting like 100 miles to a tank.
-JSpecEk*9-
22
06-08-2006 02:26 PM
The Weather Man
08-13-2005 10:45 AM
W.O.P.
03-17-2004 08:38 PM
