1992 cx d16z6 swAP...(ecu ?)
Old Mar 16, 2004 | 03:49 PM
SLowCrx's Avatar
Default 1992 cx d16z6 swAP...(ecu ?)
Im getting ready to purchase a D16Z6 swap for my 92 CX hatch.. I know the swap will be plug and play but the swap wont come with the P28 ecu. So my ? is will I be able to run my stock CX ECU on the swap safely? I know VTEC isnt gonna work but will the CX ecu work till I find a P28?
Thanks,
Chris
Old Mar 16, 2004 | 03:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 1992 cx d16z6 swAP...(ecu ?) (SLowCrx)
i ran a dx ecu on a vtec motor no problem to get through de inspection. i had a bad cx ecu so i dont know if thats why it was running rich or not.
Old Mar 16, 2004 | 04:01 PM
Hatch-E's Avatar
Default Re: 1992 cx d16z6 swAP...(ecu ?) (boostedcivicsir)
cx use will not work corectly.. it uses a 1-wire 02. your better off getting the p28, but a po6 will work fine, but no vtec and a revlimit of 6500
Old Mar 16, 2004 | 04:35 PM
BatuKing's Avatar
Default Re: 1992 cx d16z6 swAP...(ecu ?) (Hatch-E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch-E &raquo;</TD></TR><TR><TD CLASS="quote">cx use will not work corectly.. it uses a 1-wire 02. </TD></TR></TABLE>
Ditto.. so your best bet is to either purchase a P28 or if you can (I have one for sale) get a VX ecu and you can chip with a P28 rom and it will work the same.
Eli2
Dec 18, 2009 10:22 PM
pip9
May 7, 2006 07:04 PM
crxdx89
Jan 19, 2006 04:08 PM
Coupe de'Etat94
Jun 2, 2004 09:06 AM
