Tranny Techs!
Old Mar 16, 2004 | 03:10 PM
Marauder's Avatar
Default Tranny Techs!
Okay, I just put in a performance rebuilt tranny with LSD in my 00 Civic EX. It started leaking fluid, which isn't cheap by any means being $45 a case for Kaaz oil! Found out it was from the case bolts not being tight.
My question is, would just torquing them all down be okay, or do the cases need to be split and resealed??
I just don't have experience with trannies....and wonder if once the sealer is breached, whether it would still continue to leak even if the case bolts were all torqued back down.
TIA!
Old Mar 16, 2004 | 06:38 PM
doublejz's Avatar
Default Re: Tranny Techs! (Marauder)
$45 a case? i spend like $50 something for a 2 quart can
Old Mar 16, 2004 | 06:55 PM
Dan GSR's Avatar
it is best to crack the case, and re seal it, the mating surface needs honda bond
Old Mar 16, 2004 | 06:57 PM
mmuller's Avatar
Mad Scientist
Default Re: Tranny Techs! (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote"> the mating surface needs honda bond</TD></TR></TABLE>
Old Mar 17, 2004 | 07:16 AM
Marauder's Avatar
Default Re: Tranny Techs! (mmuller)
case = can (sorry....fast fingers I have) It was $45 for a 2 liter can.
Well, my mechanic looked over the tranny. The five bolts on the bottom of the tranny came loose and started to back out and the fluid was leaking out of the ends of the bolts. The case stayed together and so did the bond around the outter edge.
Everything was cleaned up and bolted back together with HondaBond on the threads of the bolts and all the bolts on the case were tighten back down.
Guess we'll see how it goes.
MySickSi
Apr 8, 2012 11:03 AM
Pishpeng
10
Feb 15, 2007 02:44 PM
Ej1_coupe
May 17, 2005 08:37 PM
CardDealer
12
Apr 1, 2005 02:51 PM
95gsr
Jun 20, 2003 09:54 AM
