Welding aluminum?
Old Mar 16, 2004 | 02:11 PM
T25So's Avatar
Default Welding aluminum?
Well, I have a dc shifter, and it looks like a giraffee neck! So I want to saw about 2" out, and weld it back together....can you weld aluminum? I dont think so, so anyone have any ideas of how to shorten it?
Thanks,
Nick
Old Mar 16, 2004 | 02:34 PM
perlmeister8's Avatar
Default Re: Welding aluminum? (T25So)
Yes aluminum can be welded. I would like you said, cut it off then take it to a shop that can weld aluminum and you are set
Old Mar 16, 2004 | 02:39 PM
Heylookits shawn's Avatar
Default Re: Welding aluminum? (perlmeistere81)
why would you do that.....just cut that much off the top and re thread it
much simpler and can be done by yourself
Old Mar 16, 2004 | 02:51 PM
T25So's Avatar
How do you re thread it?
Old Mar 16, 2004 | 03:08 PM
Default Re: (T25So)
With a tap set, you can get em at any auto store.
Old Mar 16, 2004 | 03:10 PM
T25So's Avatar
What level of difficulty is it to do?
Old Mar 16, 2004 | 03:13 PM
Default Re: (T25So)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T25So &raquo;</TD></TR><TR><TD CLASS="quote">What level of difficulty is it to do?</TD></TR></TABLE>
Probably a 2 out of 10, just make sure that the threads match the one you cut off. If you have an mechanicly inclined friends or someone who knows what they are doing it should be simple.
Old Mar 16, 2004 | 05:22 PM
turbo96wr's Avatar
Default Re: (perlmeistere81)
before you thread that shifter you must have the correct pitch dia. for that die to work.
Old Mar 16, 2004 | 05:36 PM
doublejz's Avatar
Default Re: (turbo96wr)
hehe, if you can hold a wrench staright and turn it at the same time, you'll be ok. Yes you can weld alumin, just welding alum to steel doesn't go well sometimes
Old Mar 16, 2004 | 05:43 PM
SimbaDogg's Avatar
Default Re: (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">...Yes you can weld alumin, just welding alum to steel doesn't go well sometimes</TD></TR></TABLE>
yeah...i always knew it was a bitch. but i was watching something about one of the gt500 nsx's, and how they needed to weld in a steel 12 point cage (i think) it was a real bitch and a half
Old Mar 16, 2004 | 06:26 PM
Sliced Beard's Avatar
Default Re: (SimbaDogg)
i am a welder
welding is very simple just daunting to the unknowing
if you cut it shorter and attempt to re thread it you will have to make shure the outside diameter is the same as the diameter of the current threaded part.
i would definately say leave it alone and just buy another shift lever
because to me it sounds like you do NOT have the knowledge to modify
your shift lever properly.
Old Mar 16, 2004 | 06:30 PM
T25So's Avatar
I dont know how to weld if thats what you meen. I could prolly re thread it, but I think ill just do the original plan and get it welded by a friend.
Old Mar 17, 2004 | 09:25 AM
Default Re: (T25So)
and if your friend doesn't prep it properly you will have a shift lever break off in your hand because it was not welded or prepped properly
just remember that i told you so if it does happen
just get a new shift lever
B&M shift levers tend to be a bit shorter than any other and i personally like the way they feel
Old Mar 17, 2004 | 11:54 AM
onePOINTsix's Avatar
Default Re: (dirtyd463)
sence when is welding aluminum easy? i'm just starting to learn to tig and i've welded satinless good... but aluminum is a PITA, i always tend to not realise that the material is melting and not get the filler in in time. MIGing aluminum is pritty simple but it's usually not that strong
Old Mar 17, 2004 | 04:57 PM
Default Re: (Sideout)
TIG welding aluminum is super simple
you just have to remember that you can't see a heat difference like steel
it is more of a trial and error learning experience
once you figure out what you are looking at, it is a rsather easy material to weld
now 6alV4 titanium is a PITA to weld
Old Mar 17, 2004 | 07:43 PM
GSRoadRage's Avatar
Quote, originally posted by doublejz »
WTF!? I have never heard of welding alum to steel...Steel to stainless steel yes, but alum is only compatible with alum.
You might not want to try welding an aluminum shifter, if it is heat treated you'll either end up with weld crack issues or it's just going to snap off under a hard shift either below or above the weld. Unless you have some way of re-heat treating the shifter after welding. If you have any machine shops in your area just take it to them and tell them what you want to do...any capable machinest should have the correct dies and know how to pull it off no problem.
Old Mar 17, 2004 | 08:46 PM
jdmdaily4u's Avatar
Default Re: Welding aluminum? (GSRoadRage)
this guy is right i weld steel cylinder tanks all day long aluminum won't bond to steel and another thing just take a hack saw cut the shifter but make sure its not to low because it tapers off to be wider for strength(too low the **** wont fit) and you dont need a tap just a die go to sears ask for a tap and die set. also pitch (how high the threads are) doesn't usually matter shift ***** for the most part are universal they have little plastic fittings, Also quick fix if you cut the short throw to low but the **** still fits but the plastic **** insert wont fit take electrical tape rap the top of the short throw and tighten the **** to that IF YOU DONT USE THE TAPE AND YOU TIGHTEN METAL TO METAL IT WILL RATTLE LOOSE AND DRIVE YOU NUTS!! been there tried that GOOD LUCK
Old Mar 17, 2004 | 09:16 PM
The only way to combine aluminum and steel is elmer's glue, not too strong though, lol.
Old Mar 17, 2004 | 09:41 PM
naaa jb weld works good
BTW it is impossible to weld aluminum to steel
however it is possible to weld stainless to steel and brass to steel
TEGNO1
Welding / Fabrication
16
Jan 18, 2007 02:18 AM
MidShipCivic
10
Apr 29, 2006 10:07 AM
mrbsponge
11
Apr 9, 2006 09:27 PM
DB1_559
Oct 20, 2005 12:05 AM
Chiovnidca
Jun 16, 2005 07:14 PM
