Heater Core? I have no heat?!?!
Old Mar 16, 2004 | 12:37 PM
poppycock's Avatar
Default Heater Core? I have no heat?!?!
CAn anybody help me on what is wrong. I have no heat when i move the temp slider to hot...it stays cold..i have been thinkin it might be the thermostat but i cant find on...if there is one..or it might be that the heater core is no good or it is disconnected for some reason. Another suggestion is that the slider cable came off the **** itself..any suggestions...i dont knwo hwo to take off the bezel that houses the heating buttons...please help!!!
poppycock
poppycock's Avatar
Default Re: Heater Core? I have no heat?!?! (poppycock)
and i dont knwo where the heater core is located or where the hoses are that connect to it
Old Mar 16, 2004 | 12:39 PM
AzntaggeR's Avatar
TSPeed Factory
check your thermostat and maybe check your coolant. when mines had air in the coolant my heater wouldn't get hot. try all the easier stuff first. the heater core is located underneath your dash.
Old Mar 16, 2004 | 12:44 PM
hybr1deg's Avatar
Default Re: Heater Core? I have no heat?!?! (AzntaggeR)
yeh but it's a pain in the *** to get to. yeh check your thurmostat first like he said. if it's suck shut then you won't get any heat. always while your behind your dash make sure the plugs to your heater controls didn't come loose. that happneds sometimes. na when you check yer fluid make sure to burp your hoses...
Old Mar 16, 2004 | 12:49 PM
BatuKing's Avatar
Default Re: Heater Core? I have no heat?!?! (hybr1deg)
If your thermostat was stuck then your car will also overheat.. most go open when they break.. check the line that goes to your heater core and then check the water valve to make sure its moving.
Old Mar 16, 2004 | 02:03 PM
EKCivicR's Avatar
You should do a forum search. This issue has popped up many times...
If your heater was working before and suddenly just stopped working then I am almost sure it's your wire that connects to your hot/cold slider or **** or your fan control ****/slider.
Otherwise check your control valve by the firewall & thermostat.
2002hondaCivic
Honda Civic (2001 - 2005)
Apr 13, 2018 03:50 AM
ComicConBooBoo
13
Jan 2, 2011 07:01 AM
candyman206
Dec 1, 2009 07:48 AM
iwantspeed
12
Jan 26, 2007 01:29 PM
hardboiled egz
Dec 10, 2002 08:10 PM
