can't get going over 55 or 60
Engine sounds like its reving higher than tack says.doesnt feel like 5th gear is opening all the way up.Then wants to Idle high and stall?Whats going on?Oh yea 91 prelude si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">Bad catalytic converter??</TD></TR></TABLE>
That's my guess!!!! You don't have a check engine light on?
I didn't think of that.I just had emissions done and it passed.Could it be bad and still pass?No check engine light though.I just put the motor in the car in Feb.Whats the best way to tell if the cat is bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">5 speed? if the engine revs but the car doesnt move much im gonna go w/clutch.</TD></TR></TABLE>
He said that it just FEELS like it is revving higher than what the tach displays. Definitely not the clutch. My brother described the symptoms the SAME way.
ok well i read it wrong
I messed with the cat last night and will see if it helps on the way home from work today.It felt better on the way to work today, but all I did was sit in trafic.The real test will be the no trafic ride home.Do any of you know where the horns bolt up?I just cant find the wires for them.
my friend had the same thing happen to his car on the highway...We checked it, one of his spark plug wires were shot...change out the wires and the plugs, that may fix the problem...
It sometimes is the smallest things that need to be checked
