How did this happen?
Old Mar 16, 2004 | 09:29 AM
the_0ne's Avatar
Default How did this happen?
I had oil leaking from the cam gear side of the engine, I think I found the problem
Whats the best way to put this gasket on the valve cover? little taps with a Rubber Mallet?
Old Mar 16, 2004 | 09:30 AM
BauleyCivic's Avatar
Risky Business
Default Re: How did this happen? (the_0ne)
Um looks like you left the same valve cover gasket on for too long. FYI...honda says to replace it every time you take the valve cover off...us HT people re-use that damn thing like 15 times. Here's an idea...get a new gasket, put RTV sealant around the bottom, and try not to take your valve cover off as much.
Old Mar 16, 2004 | 09:33 AM
xerox445's Avatar
Default Re: How did this happen? (BauleyCivic)
get a new set, and get some hondabond!
Old Mar 16, 2004 | 09:34 AM
smnowell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Um looks like you left the same valve cover gasket on for too long. FYI...honda says to replace it every time you take the valve cover off...us HT people re-use that damn thing like 15 times. Here's an idea...get a new gasket, put RTV sealant around the bottom, and try not to take your valve cover off as much.</TD></TR></TABLE>
Don't go crazy with the RTV. I only use it in the honda specified locations, which are those flat spots right around the humps for the cams. Other than that, make sure the gasket isn't dry rotted or anything. Also, make sure you have your valve cover bolts on tight enough, but not TOO tight or you WILL break them
Old Mar 16, 2004 | 09:36 AM
the_0ne's Avatar
this gasket was brand new, used for 1 week
Old Mar 16, 2004 | 09:38 AM
smnowell's Avatar
Default Re: (the_0ne)
It snapped after 1 week of use? That is random. I bet that when you put it inside your valve cover and put the valve cover back down, the gasket came out of the groove of the valve cover and got caught between your head and the valve cover and ended up cutting it. That's is my best guess...
Old Mar 16, 2004 | 09:39 AM
Grimm's Avatar
looks like it might have been pinched?
Every time.... damn I didn't know that...Time to look around mine...
Old Mar 16, 2004 | 09:57 AM
Eg Smurf's Avatar
Wow those things are very strong too. I remember my friend using a torch on it and it barely melted it. Wouln't recommend those kids trying it!!! It was an one he just took off a car so it was just laying around. Just get a new Seal and your good.
Old Mar 16, 2004 | 10:04 AM
Brewer's Avatar
Default Re: (l0utkastl)
Nah, you can reuse that again
Old Mar 16, 2004 | 10:06 AM
Root79's Avatar
Default Re: (BrewerHatch)
That mean other gaskets in the same condition.
Old Mar 16, 2004 | 10:09 AM
xerox445's Avatar
i put hondabond all around it, not just in the corners...no leaks 4 me
Old Mar 16, 2004 | 10:10 AM
Root79's Avatar
Default Re: (Root79)
Upsss, it looks like I'm wrong.
Old Mar 16, 2004 | 10:14 AM
Grimm's Avatar
Default Re: (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">i put hondabond all around it, not just in the corners...no leaks 4 me</TD></TR></TABLE>
yea I've never used that stuff either...
Every go to a place and over hear people talking about doing something and you think to your self... hey I just did that, well not that, nor that, oh **** nor that... And then finally realize your a ******' moron cause you attempted to do something but yet every part of it you did wrong...
ding ding ding....
points to self...
Old Mar 16, 2004 | 10:17 AM
1hotcivicSi's Avatar
nothin to it buy a new one replace it ..... juss becarefull when u put it in that it doesnt catch the edge make sure it stays in place
Old Mar 16, 2004 | 10:35 AM
the_0ne's Avatar
Default Re: (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">It snapped after 1 week of use? That is random. I bet that when you put it inside your valve cover and put the valve cover back down, the gasket came out of the groove of the valve cover and got caught between your head and the valve cover and ended up cutting it. That's is my best guess...</TD></TR></TABLE>
thats what happen
damn oil all on the side of my engine, oh well
thanks for the help everyone Im heading to a local honda dealer tonight
Old Mar 16, 2004 | 10:46 AM
SOHC_MShue's Avatar
definantely get hondabond. I used another silicon gasket sealer and it worked like crap compared to the hondabond. I still saw a slight amount of oil leakage around the edges, but with the hondabond there is none. Also all you need it to put the sealer on the flat sports where the cam seals are. No need to put it all around the gasket.
Old Mar 16, 2004 | 11:02 AM
warwagon's Avatar
i'd say you pinched it like a loaf dude
Old Mar 16, 2004 | 11:16 AM
hondasport2000's Avatar
I'm thinking the same thing.
Old Mar 16, 2004 | 01:42 PM
the_0ne's Avatar
do you really need hondbond?
Old Mar 16, 2004 | 01:49 PM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_0ne &raquo;</TD></TR><TR><TD CLASS="quote">do you really need hondbond?</TD></TR></TABLE>
hondabond or some RTV
Discosteak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_0ne &raquo;</TD></TR><TR><TD CLASS="quote">do you really need hondbond?</TD></TR></TABLE> its highly recommended
Old Mar 16, 2004 | 02:14 PM
2lua's Avatar
look like it got twisted and cut remember to torque your valve cover.... 7-8lb-ft
Old Mar 16, 2004 | 02:20 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">It snapped after 1 week of use? That is random. </TD></TR></TABLE>
install error , I'm guessing improper torque specs.
its only 10 ft/lbs.
SpeedoKing
Mar 10, 2009 09:53 AM
RGK500
Feb 15, 2007 08:23 PM
dc5tegk20
Aug 24, 2006 12:40 AM
crx_88_si
Jul 29, 2004 08:47 AM
type Gendy
10
Sep 6, 2003 10:44 AM
