d16a6 cam compataible with d15b7 head?
I know the stock cams are interchangable but I was wondering if I could get an aftermarket cam for an a6 and use it in my b7. Aftermarket valve train components are rare for the b7 as you might imagine. Thanks,
Matt
Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback19 »</TD></TR><TR><TD CLASS="quote">I know the stock cams are interchangable but I was wondering if I could get an aftermarket cam for an a6 and use it in my b7. Aftermarket valve train components are rare for the b7 as you might imagine. Thanks,
Matt</TD></TR></TABLE>
from what i have been reading is that the cams are interchangable. you just need to get an adjustable cam gear to compensate for the 1/2 tooth differance from the A6 cam to the B7 cam. But with an aftermarket camshaft you should get the gear also so timing can be dialed in.
what happens if i dont use an adjustable cam gear? what if i use the stock b7 cam gear?
Do i have to change my valve lash? if so what are the settings?
Works just fine, just swap the b7 out for the a6 do a valve adjustment put an adjustable cam gear on set it half tooth advanced and your set. Stock valve train will be fine...its not that aggressive. I did this setup myself and it gave my d15 a bit more pep
Mister Bones Dyno:
Mister Bones Dyno:
DelSolDon
Apr 23, 2005 09:52 AM
