lubricant for window rubber lining
Old Mar 16, 2004 | 08:24 AM
0ptimus prime's Avatar
Default lubricant for window rubber lining
what kinda lube should i use to lubricate the rubber lining that surrounds my window?
The window keeps coming off track and it's really pissing me off
Old Mar 16, 2004 | 08:27 AM
h22avid's Avatar
Default Re: lubricant for window rubber lining (0ptimus Prime)
Most of the time if you just wax the rubbers it keeps them from sticking. I've actually heard that as a tip for storing your car for long periods to apply wax to all of your window and door trim to keep them from sticking.
Old Mar 16, 2004 | 08:32 AM
degooser's Avatar
i use silicone spray on my window tracks and it works awesome...
only thing is that if you get a lot on your windows its kinda hard to take off....but it does come off...
Old Mar 16, 2004 | 08:34 AM
Default Re: lubricant for window rubber lining (degooser)
where do you get silicone spray?
Old Mar 16, 2004 | 08:56 AM
Caveman74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">where do you get silicone spray?</TD></TR></TABLE>
Auto parts store
Old Mar 16, 2004 | 09:02 AM
h22avid's Avatar
I was going to metion that too but it can get a bit messy on your glass if you use too much.
Old Mar 16, 2004 | 09:04 AM
scratchy's Avatar
well you can use lithium grease just a little though it will bleed out onto t he window if you use too much
Old Mar 16, 2004 | 09:08 AM
Caveman74's Avatar
Default Re: lubricant for window rubber lining (scratchy)
Mine sticks all of the time. I just spray a little and it solves the problem
Old Mar 16, 2004 | 09:23 AM
Default Re: lubricant for window rubber lining (Caveman74)
just put my window back on track, and applied silicone spray on the seals, works like a charm! The window goes up and down as smooth as a virgin!
Old Mar 16, 2004 | 09:37 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Genuine Honda silicon Spray.
Black can with green writing.
It's THE ****!
satintegra
Nov 27, 2006 08:25 PM
Jonathan_ED3
Jul 5, 2006 01:52 PM
Sean @ ESG
14
Sep 9, 2005 09:21 PM
kX
Jul 9, 2005 02:51 PM
Ch33se
Jul 6, 2005 01:50 PM
