driving in the rain with CAI...
Old Mar 16, 2004 | 07:33 AM
See Are X's Avatar
Default driving in the rain with CAI...
I just recently switched over to a CAI from a short ram...I had no choice but to drive to work in the rain without the fender lining to cover my filter...when I parked, I looked at the filter and it was dripping wet...any bad side effects to this??
Old Mar 16, 2004 | 09:18 AM
Skip01's Avatar
Default Re: driving in the rain with CAI... (See Are X)
As long as you don't floor it when running through water or go through 3ft of water you should be all right.Or you can just get a bypass valve and be really sure.
Old Mar 16, 2004 | 11:41 AM
jolt-tsp's Avatar
Default Re: driving in the rain with CAI... (Skip01)
As long as the engine doesn't die you should be okay. After you stop you may want to run the engine at idle foor a minute or so just to be sure that it doesn't intake any water without exhausting it.
Old Mar 16, 2004 | 01:47 PM
LudeyKrus's Avatar
REPLACE THE FENDER LINING IMMEDIATELY ! ! !
Here is why you should NOT drive w/ a CAI and no fender lining:
https://honda-tech.com/zerothread?id=591622
If you have to, then just be careful. The instant that thing starts to sputter, turn it off and park it!
Old Mar 16, 2004 | 03:03 PM
See Are X's Avatar
Default Re: (LudeyKrus)
I did a compression check on it just to check, i got 124psi all the way accross...
boxeocampeon
17
Oct 15, 2009 04:13 AM
Finger Lickin' good
Oct 19, 2004 05:43 PM
SiK AcC0rD
Dec 26, 2002 06:07 AM
SOHC_MShue
Oct 16, 2002 11:18 AM
hobo79
Aug 24, 2001 09:17 PM
