EX rear sway bar: 99-00 Si endlinks only or will GS-Rs work?
I'm looking to add a rear swaybar to my 98 EX coupe. I'm going the cheap route and am just looking to add a 13mm Si bar. I know I need to get the hardware, including the endlinks.
Are the 99-00 Si endlinks the only ones that will work with an Si rear bar, or will Integra endlinks fit the Si bar, too? If the Integra enlinks will work, I could just use an Integra rear swaybar, too; right?
(And no, I'm not going to add the ITR bar + Beaks kit, and I'm not going to get the Comptech bar, either
You must use the 99-2000 SI endlinks unless there are some custom ones out there that I am unaware of. I think the bars are the same other than the endlinks but don't quote me on that. I have a 99-2000 SI swaybar that I want to sell. I also have the brackets that mount to the frame but no endlinks. The endlinks alone cost about $70.00 bucks from Honda. It might be cheaper to buy a complete aftermarket sway bar kit.
im also wonderin why the gsr end links wont work...i have a gsr rear sway bar, end links and d brakets and need to know what i need to mount it...also have omni control arms on my 2000 ex???
The control arms between EG/DC and your ex are completely different. On the EG/DC control arm there is a threaded hole for the link to bolt to the control arm. If you crawl under a 96-00 civic you will see there is just a mounting hole which is why you need the one off of a 99-00.
Here is the 99-00: http://www.hondaautomotivepart...R+ARM
Here is the one for an EG/DC: http://http://www.acuraoemparts.com/del...
Modified by JShull at 8:37 AM 10/16/2006
stuie08
Nov 25, 2006 02:30 PM
