Where does Deck Power & Remote "Come From"?
Old Mar 15, 2004 | 07:31 PM
tzenisj's Avatar
Default .
Old Mar 15, 2004 | 08:01 PM
organiz3d_chaos's Avatar
Default Re: Where does Deck Power & Remote "Come From"? (civic_rice)
if i understand what you are asking correctly......
"deck power" comes from the battery ultimately.... and remote comes from the ignition.....
aftermarket colors:
yellow = battery
red = igniton
Old Mar 18, 2004 | 05:10 PM
ekb18cCivic's Avatar
just wondering... y exactly are you doin this???
Old Mar 18, 2004 | 08:03 PM
mattEG's Avatar
Do you have a haynes manual? It says right in the wiring diagram. 15 bucks man, well worth it.
Old Mar 18, 2004 | 08:04 PM
blackhatchy's Avatar
you want to make it larger? that doesnt make sense.
Old Mar 19, 2004 | 12:30 AM
Formula 1's Avatar
Default Re: (civic_rice)
i thought the remote wire was blue and its the REM to turn on the amp? im confused
Old Mar 19, 2004 | 04:52 AM
JimmyAtlantis's Avatar
Default Re: (SikCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic &raquo;</TD></TR><TR><TD CLASS="quote">i thought the remote wire was blue and its the REM to turn on the amp? im confused</TD></TR></TABLE>
The blue wire is for power antenna...
Old Mar 19, 2004 | 05:14 AM
IHateJDM's Avatar
Default Re: (JRI94)
the remote wire is red, you can tap it as many times as you need to. mine is tapped 4 times and everything works fine. Making the yellow (constant power) wire bigger won't get you more power either. If you want more power to your speakers, get a 4 channel amp.
Old Mar 19, 2004 | 10:31 AM
Formula 1's Avatar
Default Re: (93delslo)
drop the money and time into the engine first get the audio done by a pro
froogle29
Audio / Security / Video
Oct 12, 2009 11:28 PM
D16Z6racing
Mar 20, 2007 07:37 PM
TenLarge
15
May 30, 2005 08:49 PM
civicmark
Nov 6, 2002 01:50 PM
PearlWhiteAccord
Jun 18, 2002 05:17 AM
