y7-y8 minime problems
Old Mar 15, 2004 | 06:55 PM
tommyj's Avatar
Default y7-y8 minime problems
i finished my y7-y8 mini me swap but it does not start, i didnt wire in vtec yet or i did not do the IACV mod yet, i was still using the DX ecu
car: 98 hatchd16y7
with a y8 head, y8 intake mani, and y7 Throttle body
i also have some unknown vaccum or coolant plugs which i am unsure where they go. i know a coolant line goes to the TB and there is a nother nipple open. does this lil black cylinder thing plug to it?
i think my timing is off cause my friend said he saw exhaust come out the oil hole.
i need this thing to start, so i can move it.
Old Mar 16, 2004 | 04:56 AM
tommyj's Avatar
Default Re: y7-y8 minime problems (ddp685)
bump.. anyone?
Old Mar 16, 2004 | 05:37 AM
Aquafina's Avatar
No help from me, but you didn't put the head on with that coolant in the cylinder(s) did you?
Old Mar 16, 2004 | 07:36 AM
jaxle's Avatar
yea what he said and sum info on how it does not start would help. for starters(heh heh) does it crank? do you hear the fuel pump prime? do you have compression? spark? etc. etc.
Old Mar 16, 2004 | 07:59 AM
sleepyhamsterlx's Avatar
Default Re: (jaxle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddp685 &raquo;</TD></TR><TR><TD CLASS="quote">where is the end of this part going to, looks like its going towards the alternator. Where does it lead to?
And is this one on the Intake Manifold, cause a Did a y8 manifold swap on my y7. Where does that lead to.
i need this thing to start, so i can move it.</TD></TR></TABLE>
Old Mar 16, 2004 | 09:07 AM
h22avid's Avatar
Default Re: y7-y8 minime problems (Aquafina)
I was going to say the same thing
Old Mar 16, 2004 | 10:01 AM
tommyj's Avatar
theres spark, crank and its gettin fuel. i hope its just a timing problem.
Old Mar 16, 2004 | 10:06 AM
SOHC_MShue's Avatar
so you did get the coolant out of the cylinders correct?
Old Mar 16, 2004 | 10:18 AM
tommyj's Avatar
Default Re: y7-y8 minime problems (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">so you did get the coolant out of the cylinders correct?</TD></TR></TABLE>
of course
Old Mar 16, 2004 | 01:25 PM
EvilPinkEye's Avatar
check ur timing, happened to me, damn thing wouldnt start, and at the end was one tooth off on my ***.. ohh make sure u got the tension pulley bolt nice and tight, dont wanna get into that
Old Mar 16, 2004 | 05:08 PM
tommyj's Avatar
Default Re: y7-y8 minime problems (EvilPinkEye)
i am not holding compression. 75 is the max i got, and i have a coolant issue, it sprayed out the radiator during the compression test.
a coolant line goes to the throttle body and intake mani right?
my car is in the shop now, and my timing is perfect and tensioner is tight.
could my head be cracked or warped? or have bent valves?
Old Mar 16, 2004 | 07:18 PM
Aquafina's Avatar
Compression could either be headgasket, rings, or valves/valveseats.
Old Mar 16, 2004 | 07:25 PM
tommyj's Avatar
someone told me it is possible i put the headgasket on backwards.
i think it only fits on 1 way, correct?
Old Mar 17, 2004 | 12:50 AM
JDMproject17's Avatar
check your firing order !
Old Mar 17, 2004 | 02:21 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddp685 &raquo;</TD></TR><TR><TD CLASS="quote">i am not holding compression. 75 is the max i got, and i have a coolant issue, it sprayed out the radiator during the compression test.
could my head be cracked or warped? or have bent valves?</TD></TR></TABLE>
Sounds like the timing belt isnt right. Make sure the timing belt is on the motor correctly.
liam
Old Mar 17, 2004 | 09:41 AM
Zer0DazE's Avatar
Default Re: y7-y8 minime problems (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
what would the timing have to do with the radiator being persurized when hes turning over the engine?
pull the head man... its your head gasket, or you didnt torque the head bolts properly.
Old Mar 17, 2004 | 10:00 AM
Turbo'dMex-A-Keen's Avatar
Default Re: y7-y8 minime problems (Zer0DazE)
head gasket can be backwards or u didnt connect all the coolant lines right and there is back pressure where there shouldnt be
Turbo Mex
Old Mar 17, 2004 | 10:13 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0DazE &raquo;</TD></TR><TR><TD CLASS="quote">
pull the head man... its your head gasket, or you didnt torque the head bolts properly.</TD></TR></TABLE>
oo i didnt read that part. ya pull the head.
liam
Old Mar 17, 2004 | 12:38 PM
tommyj's Avatar
its gonna get pulled, time to see whats wrong.
Cheefer_EX
14
Oct 30, 2012 08:19 PM
dxcivicsi
15
Jun 24, 2009 08:24 PM
thebleek
Sep 4, 2008 01:43 PM
shauniewalnuts
Jun 27, 2005 08:20 PM
goofyej6
13
Jul 15, 2004 12:28 PM
