Is it fairly easy to adjust your...
Old Mar 15, 2004 | 06:12 PM
FD3S's Avatar
Default Is it fairly easy to adjust your...
e-brake? never done it before. can some one walk me through it? thanks!
Old Mar 15, 2004 | 09:40 PM
FD3S's Avatar
Default Re: Is it fairly easy to adjust your... (FD3S)
h-t night crew!
Old Mar 15, 2004 | 10:09 PM
99spanishGT
Guest
Posts: n/a
im also interested!!! mine licks nuts!!! i can only pull a 540 rotation im aming for a 720!!!
Old Mar 16, 2004 | 12:20 AM
Don Jefe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FD3S &raquo;</TD></TR><TR><TD CLASS="quote">h-t night crew!</TD></TR></TABLE>
...responds with sarcasm
Old Mar 16, 2004 | 04:36 AM
cecknight's Avatar
what year? Is the e-brake in teh middle or off on one side?
Old Mar 16, 2004 | 09:19 AM
tuan...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FD3S &raquo;</TD></TR><TR><TD CLASS="quote">e-brake? never done it before. can some one walk me through it? thanks!</TD></TR></TABLE>
correct me if im wrong but.. dont e brakes adjust themselves? or was it like ur suppose to roll at like 30 and lightly pull on the e brake?&gt;
Old Mar 16, 2004 | 09:48 AM
Sephro's Avatar
Default Re: Is it fairly easy to adjust your... (v0gueSilver_Dc2)
you have to pull the center console. There is an adjuster right behind the hinge where the e-brake handle meets the frame.
You can sorta picture it in this pic. Look where the lines connect to part #9 (right in the center)
Old Mar 16, 2004 | 10:03 AM
FD3S's Avatar
Default Re: Is it fairly easy to adjust your... (Sephro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">you have to pull the center console. There is an adjuster right behind the hinge where the e-brake handle meets the frame.
is this for a 94+? does the adjuster just twist?
Old Mar 16, 2004 | 10:15 AM
Sephro's Avatar
well that pic is for mine (92) but it is the same concept in every car.
At the end of the cables there is a bolt that you turn. You want to move the cable away to make the brake tighter and move the cable closer to make it looser, if you get what I mean. Just play with it trying it after every adjustment you make until the handle catches where you would like it to.
Just make sure you don't make it too tight because then it will actually be braking when the handle is all the way down. so make sure there is some slack in the line with the handle down. Other wise you will need new pads very soon and driving with your brake on isn't so fun.
Old Mar 16, 2004 | 10:16 AM
FD3S's Avatar
cool, i'll try it. thanks a lot!
Old Mar 16, 2004 | 10:24 AM
Sephro's Avatar
the only hard part is taking off the center console. That's a PITA!
Old Mar 16, 2004 | 01:58 PM
TimeRacer's Avatar
Unsure if the 4th gen is anything like the 5th gen but on the 5th you can just remove the back panel on the center console and not remove the entire thing. It's a lot less time consuming.
Old Mar 17, 2004 | 07:21 AM
Sephro's Avatar
Default Re: Is it fairly easy to adjust your... (TimeRacer)
I am unsure about the 4th gens that have the short console but in mine it's all one piece from right behind the shifter to the trunk.
Old Mar 17, 2004 | 07:34 AM
Behan's Avatar
its neccesary in all 4th gens. i have a 93 but i don't see how 94-96 could access it without removing the console.
Old Mar 17, 2004 | 01:54 PM
TimeRacer's Avatar
Default Re: Is it fairly easy to adjust your... (Behan)
5th gen: See the plate at the back of the console? That's what I was referring to. Makes it much easier to just pop that off to adjust the e-brake
4th gen: Doesn't seem like it has the plate and you do have the remove the entire center console.
Old Mar 17, 2004 | 07:08 PM
vtk94lude's Avatar
mines adjusted as far as it goes and its still loose, is it possible to adjust the e-brake form the rear discs? or there abouts?
scottydotty
Jul 8, 2008 10:57 AM
NMZ
Mar 3, 2008 06:46 PM
IBriaIN
May 25, 2007 01:21 PM
SLVRSTN_DC4
Honda S2000
May 24, 2007 08:51 PM
People_Mover
Aug 14, 2004 08:43 PM
