manual steering conversion?
Old Mar 15, 2004 | 12:35 PM
BmCRace.com's Avatar
Default manual steering conversion?
i got a 93 civic ex coupe and it has power steering, i was wondering if anybody knows how to convert it over to manual steering and if anybody happens to have the parts to do it. i am located in houston tx if that means nething to you.
Old Mar 15, 2004 | 12:41 PM
Street Ghost's Avatar
Default Re: manual steering conversion? (bmc racing)
I did the same thing to my 93 EX Coupe. I looped the system and attached a breather resevoir to it. I bought the parts off a fellow H-T member here.
https://honda-tech.com/zero...age=3
Old Mar 15, 2004 | 02:45 PM
Bnjmn's Avatar
Piece of cake if you have the ps subframe to start out with.
Buy a 94+ Integra rack and it bolts right up. Buy a 1/4" NPT hose barb adapter- it works fine in the metric threads on the ps rack- just put some honda-bond on the threads. Then loop it to a plastic breather bottle. I used the container from a Lisle brake bleeder kit which cost $6. I drilled holes in the bottom of the plastic container and then screwed in NPT-hose barb adapters.
This will make more sense when the parts are sitting in front of you, but it is a pretty easy swap.
Ben
PhrequenC
Suspension & Brakes
Feb 15, 2008 02:18 PM
tthame1
Jun 21, 2004 01:50 PM
rjr162
Aug 18, 2003 09:41 AM
AThiker
Sep 24, 2002 07:05 AM
