need some help with my ls
Old Mar 15, 2004 | 05:14 AM
SpoonyGSR's Avatar
I hate rap music
Default need some help with my ls
ok i assembled my ls motor ad everythign from the oil pan. to the cams. im working on the timing belt now. the cranks pulley is at tdc, (red white red mark its straight up) now when i put the cams in the marks wernt straight up. i try turning the but the valve springs wont let thestay. this is the only difficult part i am having. anyone have soe info or advice they could lend?
Old Mar 15, 2004 | 05:33 AM
Dan GSR's Avatar
Default Re: need some help with my ls (spoonie_GSR)
the cam caps nearest the timing belt has a hole for a 5mm punch to hold the cam at tdc
also tdc on the pully is the white mark furthest from the group of three
what i usually do is put a long as extention in #1 spark plug hole to visually make sure i have tdc
if your putting the timing belt on, there is a mark on the oil pump gear that points to an arrow on the oil pump
IntegraMark
Sep 29, 2009 05:07 PM
stevew84
Oct 9, 2008 07:04 PM
jaredvabeach
Jun 18, 2008 01:43 PM
ganjasnack
Jun 12, 2007 01:22 PM
ganjasnack
Jun 12, 2007 09:15 AM
