new ls/vtec swap wont start in 92 eg hatch
Old Mar 14, 2004 | 08:23 PM
Tex Blackwell's Avatar
Default new ls/vtec swap wont start in 92 eg hatch
ok, it had an ls orgionally in a 92 si hatch. I'm not sure whether the guy who used to own it put an ls wiring harness or used the stock si harness. one problem is, when i go to start it up, the starter, the shaft thing will push out, but it wont spin the motor, so i check all the wiring , everything looks fine, i try again, it sticks back out but wont spin the motor, i still dont have the vtec wires hooked up yet.
i put a obd0 b16 top end on the ls bottom end, i used the obd1 injectors and ls throttle boddy. i have all the hoses and everything hookedup, somewhere i'm messedup on the wiring, and can some1 show me how to hook up the vtec?
Old Mar 14, 2004 | 08:34 PM
trooper0641's Avatar
Default Re: new ls/vtec swap wont start in 92 eg hatch (mp3albums2k2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp3albums2k2 &raquo;</TD></TR><TR><TD CLASS="quote">ok, it had an ls orgionally in a 92 si hatch. I'm not sure whether the guy who used to own it put an ls wiring harness or used the stock si harness. one problem is, when i go to start it up, the starter, the shaft thing will push out, but it wont spin the motor, so i check all the wiring , everything looks fine, i try again, it sticks back out but wont spin the motor, i still dont have the vtec wires hooked up yet.
i put a obd0 b16 top end on the ls bottom end, i used the obd1 injectors and ls throttle boddy. i have all the hoses and everything hookedup, somewhere i'm messedup on the wiring, and can some1 show me how to hook up the vtec?</TD></TR></TABLE>
vtec doesnt have anything to do with the car starting up...
Old Mar 15, 2004 | 04:28 AM
Default Re: new ls/vtec swap wont start in 92 eg hatch (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">
vtec doesnt have anything to do with the car starting up...</TD></TR></TABLE>
i know
Old Mar 15, 2004 | 05:21 PM
ok, nevermind turns out the starter is bad, but how does it go bad? i took it off, 2 days later, i put it all back and it wont crank? I"m getting a new new starter tomorow, had 2 push start it. new problem now though,
the car is idling funny, not normal like it used 2, it hops from 1500-1300 up and down, at a constant rate.
Old Mar 15, 2004 | 05:50 PM
Kimbo's Avatar
vacuum leak? any cel.. usually the cel will tell you...
Old Mar 15, 2004 | 06:10 PM
jameskersten1's Avatar
[QUOTE=mp3albums2k2]ok, nevermind turns out the starter is bad, but how does it go bad? i took it off, 2 days later, i put it all back and it wont crank? I"m getting a new new starter tomorow, had 2 push start it. new problem now though,
QUOTE]
did you over tighten the nut holding the main power? if you did u might of twisted the contacts inside the starter. try looking at those.
Old Mar 15, 2004 | 07:48 PM
Default Re: new ls/vtec swap wont start in 92 eg hatch (jameskersten1)
actually, when i hooked up the main power bolt, it did twist a little bit, what do i do about that?
Old Mar 15, 2004 | 07:58 PM
FRANKENSI's Avatar
what to do?? what to do??
ROCK IS THE 21st TEX!
pnutz
Apr 10, 2008 08:37 PM
Silspeg6
Jan 31, 2006 05:02 PM
slow92EGSi
Dec 28, 2005 05:04 PM
baam
Sep 26, 2005 08:13 AM
