b18b swap idling too low...i need a list of what to check!!!
Old Mar 14, 2004 | 07:04 PM
dingusjt's Avatar
Default b18b swap idling too low...i need a list of what to check!!!
ok this is for a friend...he just did a b18b swap, running obd0, with b16 manifold and dizzy and runing a b18a1 ecu, his car is idling low so low that it just dies constantly...the timing appears to be fine, and the only codes are speed sensor.
so can you guys start listing things to check so we can troubleshoot this thing?
thanks.
Old Mar 14, 2004 | 07:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: b18b swap idling too low...i need a list of what to check!!! (dingusjt)
Check your FAITV and your IACV as well as your tb idle scew which is where the throttle cable attaches. Go from there.
Blaze
Old Mar 14, 2004 | 07:24 PM
sikcrx80's Avatar
if not just turn up idle see if that helps
Old Mar 14, 2004 | 09:44 PM
CTR-CRX's Avatar
Try the idle screw but if not that move ur distrbutor forwards to advance it
racinmason85
Apr 5, 2019 05:12 AM
m00nr0ck Si
May 16, 2007 07:39 AM
95_red_dc
Oct 16, 2006 04:00 PM
dsmarefaster
May 15, 2005 03:55 PM
Audipwr1
Jul 6, 2003 10:27 AM
